Thread: Pump draining overnight
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    My pump looses prime overnight. It is about 10' higher than the pool, and i notice that the basket empties out when the pump shuts down for the night. It always re-primes on it's own and has protection if it wouldn't, I just worry that this is a problem. I do not have any check valves, and the plumbing is real tight, so I would have to replace a lot of stuff to try to squeeze one in.
    Is this a result of the elevation, or is there an issue? Do I need to fix it, or since the pump can re-prime in a few seconds, is it OK?
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pump draining overnight
    I think as long as it primes with no issues it's OK. 10' is a lot, and even the tiniest leak anywhere will let air in and water out.
    forya's Avatar
    Jun 2013
    49
    The only issue I might have is with my Hayward chloranator ( I know you guys hate these, but I have to travel too much, and use bleach when I am home.). When my water drains back to the pool my chloranator will drain too? Will it recover when the pool pump starts up? I can't see what goes on inside the thing.
