Thread: Very very light tint of green
    My pool motor had some issue and for that reason the motor didn't run for 5 days, finally the motor is fixed now, but I am seeing very very light tint of greenish color in the water... what shall i do? I checked Ph level and that looks OK...... please suggest...thanks
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    Mar 2014
    Las Vegas
    288
    Re: Very very light tint of green
    Post up a full set of test results and someone will come along and get you headed in the right direction. More importantly, what is your chlorine level?
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
