Thread: Calcium hypochlorite?
    I was planning on shocking my pool to raise chlorine level to proper range of 8 ppm. My question is if I use hypochlorite shock will that raise my CYA or just my calcium hardness? How much will a bag raise my CH?
    My chemistry is
    FC = 2.8
    PH = 7.6
    TA = 80
    CH = 210
    CYA = 120
    20,0000 gallon plaster pool
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Calcium hypochlorite?
    Pool Math will tell you everything you need to know.
    At the bottom, use the Effects of Adding Chemicals after you put in your volume at the top.
    Isolated Spa - 345 Gallons
