Results 1 to 7 of 7
Thread: Discolored water -- Kicking myself
    Apr 2013
    Battle Creek, MI
    298
    I needed to add 2-3 inches to the pool yesterday, and instead of dragging out the long hose reel and stringing it across two yards to get to my father-in-law's municipal water supply -- the only water I've ever used to fill and refill my pool -- I got lazy and decided to just use our nasty well water. I thought I could be clever and put the hose directly into the skimmer, thinking the D.E./cellulose filter would somehow make a difference. But I could tell as the day went on something wasn't quire right, and this morning when it's overcast I could see an obvious greenish tint to the water. Even my 10-year-old disabled daughter noticed it right away! I tested last evening around 6, after the kids had been in it, and I had 3 FC and 0.5 CC, so I added 20 oz. of 12.5% chlorine. This morning the numbers are good -- 5.5 FC and 0.0 CC (pH both days a perfect 7.5), but the color has me bummed. Is this rust? What is going on?
    (Side note: Water wasn't the only variable yesterday, as I also added the new Confer steps to the pool. They are weighted down my three bleach jugs filled with sand, water and a little chlorine and sealed tightly. Is this a factor in any way?)
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Discolored water -- Kicking myself
    So you didn't test after the bleach addition last night to compare?
    I'd say its from the well water. Go ahead and add some of the recommended sequesterants and see if it helps.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Just a guess but I'd bet your well water has iron. If you know this to be true, add sequestrate (eg jack's magic pink stuff or Metal Magic are the two brands this forum typically recommends for metals). Your water may be a bit cloudy while the sequestrate "attaches" to the metal but leave the filter running and It will clear. Also, you may need to add maintenance doses per bottle instructions to keep metal staining at bay if there was a good bit of iron in your well.
    I am on well water but I run my outdoor tap through th water softener now, and filter the hose to be safe. But I do still have to rely on sequestrate to keep the metals at bay
    Oops, cross-posted
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by frustratedpoolmom View Post
    No. I added chlorine to the 3 ppm, circulated and left it overnight. It apparently held the chlorine as this morning FC was up to 5.5 and CC was gone.
    11,969
    Probably from the well water then.
    Apr 2013
    Battle Creek, MI
    298
    I ended up going to the local pool store and picking up some of their sequestrant. I can't wait long enough for one of the recommended brands to arrive. I had to do something! The salesman was concerned that I had already added chlorine, thus making the job more difficult. We'll see how it goes. Thanks for the quick answers.
    Apr 2013
    Battle Creek, MI
    298
    Happy to report that, after running the pump/filter for nearly 24 hours, the sequestrant seems to have done the job Filter pressure went from 14 p.s.i. to more than 20 and return pressure was almost non-existant until I "bumped" the D.E. filter a half dozen times.
