Results 1 to 8 of 8
Thread: Backwashing
    May 2014
    Upstate NY, US
    64
    Backwashing
    I'm a bit unsure of how to do this properly, so I figure the pool geniuses here will know. Based on what I read, it appears that I should follow this protocol:
    1. Shut Pump off
    2. Switch Filter to Backwash Mode
    3. Turn pump back on
    4. Let it backwash until sight glass is clear
    5. Turn pump off
    6. Turn back to Filter mode
    7. Turn pump back on
    I read that some people like to run it on rinse after, what do you guys think? Want to make sure I do it right.
    My pool: 13,500 gallons round pool, 24' w 52" above ground, hard sided pool. Jacuzzi 190L Sand Filter, 1 Horse Waterway pump, Robotic Vacuum
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Backwashing
    Yes set it to rinse after, watching the site glass for clear water. About 45 seconds to a min
    May 2014
    Upstate NY, US
    64
    Re: Backwashing
    45 seconds to a minute of backwash? Or 45 seconds to a minute of rinse?
    Thanks
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Backwashing
    ....about 45 seconds min RINSE.
    Do you have the owner's manual?
    You're done SLAMing when:
    May 2014
    Upstate NY, US
    64
    Re: Backwashing
    Quote Originally Posted by Butterfly View Post
    I'd have to look, it came with the house.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Backwashing
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: Backwashing
    I alternate back and forth between backwash and rinse a few times, not just once. Even though it runs clear after the first rinse, if you do it a few more times, you will see more crud come out. Of course you lose more water, but it's cleaner.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    May 2014
    Upstate NY, US
    64
    Re: Backwashing
    Yes, that is it Richard.
    Quote Originally Posted by steveg_nh
    Yeah, I think I may have too, I'm gonna have to add water before I can backwash hard core. I'm going to have the better half hook that up tonight and add water, hopefully it won't slow down my SLAM too much.
