Thread: CYA test....how long?
    I added 3lbs of granular stabilizer yesterday. How long does it take to show up on my tf-100 test? I did the test several times yesterday before adding and kept getting 0. Black dot never disappeared. Tested it this morning and black dot still did not disappear.
    18x38 IG liner salt water pool, pentair cartridge filter, whisper flow two stage pump, Hayward t-15 cell, Hayward aqua plus, legend cleaner
    Jan 2013
    Houston, TX
    1,079
    Re: CYA test....how long?
    I takes a week for cya to show up on the test. Function on the assumption that you are at your targeted level.
    Did you use the sock method to but the cya in?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Quote Originally Posted by karmabiker View Post
    Ok thanks. Yes I did use the sock method. Should I go ahead and add the other 2lbs.? It's a 5lb container. I need 363oz. per my pool math to get it to 70.
    Jan 2013
    Houston, TX
    1,079
    I would wait a week and check. Cya is not one you want to overshoot.
    Definitely, thanks
