Thread: IC40 reading high salt?
    Jun 2014
    Roanoke, TX
    2
    Hello everyone,
    Inaugural post here so please go easy on me... My Pentair IC40 has been working well until here recently. After the winter I added a lot of salt to get back to where I was supposed to be. I watched the salt ppm shoot up as expected and then slowly taper down over a few weeks. It bottomed out around 3100ppm, and then mysteriously has started increasing slowly. Chlorine generation was normal and all was well. I thought it would just go back down on its own. Yesterday I ran a water test and came up with very low chlorine. I checked the salt ppm via my panel, and it showed 3900ppm. Took water sample to Leslies pool and they told me that it was 3100ppm. (less than 20 minutes between sample taking and tesing at leslies) They advised I also add some shock and acid, which I did when I got home. I also acid washed my IC40 thinking that would help. After reassembly and adding the shock and acid, I rechecked the salt ppm and it is reading 4250 ppm. I may be mistaken, but I thought that the only way the number for salt ppm could go up would be addition of salt, or extreme evaporation? After reading more on this forum I also have a sick feeling that the previous owner may have steered me incorrectly on maintenance. He told me to use straight muriatic acid for the acid washes. I read the manual finally and this forum and see that it should be 1 part acid to 5 parts water. The only good thing is that I have only let the acid sit in the cell for less than 5 minutes each time. Have I toasted my cell? Why did it stop chlorine generation if is thought the salt ppm was 3100? How can salt ppm reading increase without addition of salt? My IC40 is version 2.something.
    Thank you in advance.
    Charles
    Re: IC40 reading high salt?
    Welcome to TFP!
    You probably have more than one problem going on. From what you said it sounds like the acid washing helped, revealing that you actually have too much salt in the pool. Meanwhile the earlier problem is probably a water chemistry problem, unrelated to the SWG.
    I recommend you replace some water to get salt below 4,000, and then post a complete set of water test results. That will give us a much better idea of what is going on.
    May 2014
    Mesa, Arizona
    180
    Get a good salt water test kit and confirm that the readout on your control panel is truly what it says it is. I use the Taylor K-1766 and find that my control panel differs slightly from the kit. When you are so close to the maximum of your salt generator it pays to be accurate.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
