Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Pool renovation
    Jun 2014
    Racine,WI
    10
    Pool renovation
    well hello everyone, im new here. figured id drop in to say hi, share some photos and possibly ask some advice.
    well i purchased a foreclosed house (my first house) about 1.5 years ago it had a decent sized in ground pool and we have started the renovation. She will need
    *new liner
    *new ladders/railings
    *new plumbing
    *new pump.
    I've also decided to replace and add to a section of the concrete pool deck which means I can add some lighting to the east side of my pool. my pool builder recommended two savi melody lights. will this be very bright enough? I've seen the SOL version online is brighter and the melody is a pool/spa light the pool is about 32x18. oh dont worry i will also be resurfacing the old concrete this weekend, i think the plan is to use a concrete stain then a clear coat with non skid. anyone have any suggestions on a good brand?
    here are some pictures of the pol
    After thinning out landscaping
    Before thinning out landscaping
    thanks for looking guys! any suggestions would be appreciated!
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    so far the left half of the pools concrete deck has been removed along with new plumbing and lighting installed. this weekend i should be repainting the coping, and resurfacing the remaining concrete to prep for a stain once the new concrete has been poured. All the landscaping around the pool has been removed with an additional 6 feet of concrete being added to the left side.
    Other plans for this would be learning how to care for the pool, replanting some plants, and adding a pond/waterfall near the back right corner. also moving the pump and filter set up later this summer once the garage addition is done.
    I'll add more pictures once i get home from this work trip, there is a 2.5-3 foot rock wall separating the pool area from the rest of the yard but in these pictures everything looks like a jungle. Last week i cut out 15 truck loads of trees and bushes to tame everything.
    28,000 gallon, in ground pool with vinyl liner utilizing a sand filter, date of build is unknown as i bought the property as a foreclosure. Pool is fairly old though I'm guessing 70's as the concrete around it has been redone at least once.
    Jan 2011
    Richmond, Texas
    595
    Re: Pool renovation
    Keep the pictures coming. Everyone likes to see someone take it from a swamp to an oasis.
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    I think swamp may be an understatement, but it already looks better than these pictures. i posted a lighting question in another area but do you think two savi melody leds are sufficient for a pool this size?
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    Re: Pool renovation
    Cool project! It's going to be such a change when you are finished. I'm sorry, I haven't heard of that light so don't know if that's bright or not. Good luck and definitely keep pictures coming!
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
    May 2014
    Montpelier, Virginia
    54
    Re: Pool renovation
    Looks like the same type of rebuild as mine. here is my link.
    http://www.troublefreepool.com/threa...-the-beginning
    40,000 gallon, vinyl liner, sand filter, oldie but goodie, Chef for all your cooking questions!
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    Sure does look about the same! hopefully mine will come out as good as yours did.
    well new plumbing is in, i soft scrubbed the stairs, now im thinking about trying to use CLR to remove some rust on them.
    here are some pictures of the pluming and the new hole for the lights.
    I'll have to admit that i am having a pool builder do the plumbing, lights and liner. im 25 and new to all this, im also only home about 2 days a week, on a good week so some stuff is hard to keep up with. hopefully going to resurface the rest of the concrete, and paint the steel walls this weekend.
    here are the pictures
    https://31.media.tumblr.com/af868a0d...izxbo1_500.jpg
    Casey's Avatar
    SW PA
    10,448
    Re: Pool renovation
    Keep the pics coming! It will look like a brand new pool when completed!
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    Couldn't get a hold of the pool builder but i am wondering if i should have some plumbing added for a vacuum? Right now i'm leaning towards an aqua bot jr which uses a filter, but wondering if i should add a line in case i get one that runs off a suction line. to go along with the aqua bot i was considering a hand held recharge unit. Any thoughts?
    sorry about grammer just woke up with 4 hours rest after an 18 hr shift.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Re: Pool renovation
    If I had it to do over, I'd get a robot. I have a pressure side cleaner with booster. Robots are getting a lot of good press here. When either my booster or vacuum dies someday I'm going to go robotic.
    The line seems like it would be unnecessary though it's always good to think these things through.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    Well here is an update, they finished pouring concrete this morning. A bit behind schedule due to rain but its coming along. All new pluming,LED's (went with two SAVI Melodys), painted coping and steel walls and cleaned up the stairs.
    I've been looking for a concrete grinder for rent to resurface the old concrete to prep for staining. However they are booked for weeks so Sunday I have someone coming over for an estimate, I will more than likely still do the staining,caulking **** just supply the grinder. Now all i have to do is decide on the color of liner and siding for the house garage. may take awhile im horrible with colors.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    202
    Re: Pool renovation
    looks good
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    Jun 2011
    Central Iowa
    105
    Re: Pool renovation
    Can't wait to see the progress continue! Great job!
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Pool renovation
    Looking great so far.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Casey's Avatar
    SW PA
    10,448
    Re: Pool renovation
    Keep the pics coming with progress updates!
    Jun 2014
    South Florida
    47
    Re: Pool renovation
    I noticed you used flexible PVC to run the plumbing. Never thought about using it but it would make life easier.
    Are flexible PVC lines proven to be as good as standard schedule 40 PVC? I like that flexibile PVC would eliminate the need for elbows which would improve water flow.
    Looks like a good project and it's coming along nicely!
    As for the Savi Melody, those two should be PLENTY for your size pool. Thinking of going with the two or three mini blanco or melody myself (we distribute nextstep products where I work so this is an advantage to using them). Have you been able to turn them on and test them yet?
    Currently remodeling a 1950's 15x25 14,000+ gallon IG concrete block pool myself. Old galvanized pipes, delaminating plaster, lily pad skimmer, no waterline tile, equipment pad too close to pool, etc. Follow my thread as I chronicle the remodel process.
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    The pool builder decided to use the flexible lines. I would assume that for low pressure pool use it will hold up just as well, someone more experienced should comment here but low psi and a small operating temperature range would lead me to assume it will hold up well.
    Thank you, i got home two days ago after a week of traveling and just met with a friend who will be doing the acid wash and colored sealer on the concrete, then its time to fill her up. could have wrapped this project up in a week had I planned better and been available for the entire week.
    Thank you for your comment on the melody lights, i was mainly worried because I believe they are listed as step lights on some websites.
    Anyone have suggestions on where i can try to find ladders and a railing to go with the existing holes drilled in the deep end and for the steps?
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Pool renovation
    I think I saw some specs here in long beach that actually require flexible pipe. So it won't crack if there's a shift from settling or earthquake or what ever.
    Looks like it's coming along.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    teknic88's Avatar
    Jun 2014
    LAS VEGAS
    140
    Re: Pool renovation
    Your project it's coming along perfect
    21.5K gallons... 65' x 9' Shotcrete Inground Lap Pool... 3'.5" to 6.5" Depth...9' by 7" Wet Deck... Hayward all the way... 2 L.E.D lights...Pebble Sheen Aqua Blue...And above all....LOVING IT!!!!!!
  20. Back To Top    #20
    Jun 2014
    Racine,WI
    10
    Re: Pool renovation
    Thanks guys, concrete re-finishers are running behind due to how rainy the last few weeks have been once that's done its time to fill her up
