Thread: do i need a salt water tester?
    Jun 2013
    chicago
    71
    i have (and am using for the first time) the intex sand filter/saltwater pump combo. it has a low and hi salt warning built in. just wondered if i need to invest in a salt water tester to see how many ppm it has. so far none of the warnings have gone off. though i just started using it yesterday. ive put in 120lbs of salt so far.
    if i do need it...is it something that can wait a week or 2? im kinda cash strapped at the moment with all of the other summer yard projects going on too.
    this is the kit i was looking at http://www.amazon.com/TAYLOR-TECHNOL...ater+pool+test
    maybe there is something better or cheaper. i assume the test strips are junk, just like the ones that test chemicals.
    intex 15'x48"
    intex 2650 gph sand filter/salt water pump.
    pool is brand new installed 7/1/2013 (started yr 2 on 6/2/2014)
    38,305
    Re: do i need a salt water tester?
    The strips seem to be hit and miss ... they can expire and go bad. I like the kit you posted. Although my kit seems to always read 600ppm higher than my SWG ... who knows which one is "right". The only thing that matters is that the SWG is happy.
    The kit is consistent though, so I can get a sense for if the salt level is dropping, etc. If the number for the test does not change, but the SWG starts to have issues, I can be pretty sure that it is in fact the SWG that needs attention and not the salt level.
    Jun 2013
    chicago
    71
    thanks for the info. so do you think its urgent i get one right away? or can i wait a week or 2?
    intex 15'x48"
    38,305
    It can wait if the SWG is new and working properly.
    May 2014
    Mesa, Arizona
    180
    I agree with this statement as I've found my control panel just a little off from the test kit, although usually only by 200 ppm.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
