Results 1 to 10 of 10
Thread: R-0870
    May 2013
    Norman, Ok
    35
    R-0870
    Can this Reagent go bad? After adding 40 drops of 0871 and not the slightest hint of change, I poured out the sample and opened a new canister of powder and this time, it only took 11 drops (5.5 FC)...so I'm guessing its bad?
    Also, this weekend, I added 4lbs of stabilizer. How long will this throw off my other chemical readings?
    Tonight's readings
    FC - 5.5
    CC - .5
    TA - 150
    CH - 130 - this is low according to the "pool math" page.
    PH - 7.6
    CYA - registered 35...I know this may go up over the next 3-5 days.
    Calcium Hardness is my only real concern. Can this be the result of the stabilizer?
    Thanks in advance
    Rowdy
    18 x 30 IG vinyl "sports pool" 16k
    Hayward pump & sand filter. Polaris cleaner (older model) & booster pump.
    K-2006 test kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: R-0870
    CH not affected by stabilizer. PH and TA may come down slightly. Is the pool a vinyl pool? if so 130 is fine. If it's plaster or something else, then yes its low.
    How old is your powder and where do you store your test kit.
    May 2013
    Norman, Ok
    35
    Re: R-0870
    I keep the kit in the house year round, and it was purchased right at a year ago.
    And yes, it's a vinyl liner pool.
    Thank you for the quick response!
    K-2006 test kit
    38,457
    Re: R-0870
    I have never heard of the powder going bad. What does it look like?
    May 2013
    Norman, Ok
    35
    Re: R-0870
    The powder looks normal and turns the water deep pink...but would not react to the 0871 drops. I ordered new powder and drops, so opened the new powder and got a normal 11 drop reading (I was already using new drops).
    K-2006 test kit
    Aug 2011
    Southern California
    188
    Re: R-0870
    Maybe the drops went bad and not the powder?
    Edit: I see where you now say were using new drops.
    scriptorum's Avatar
    Apr 2014
    Mt. Pleasant, SC
    126
    Re: R-0870
    Is it possible for the first titration you accidentally used another reagent that wound up in the spot where you normally keep the 871? Another thought is for the first sample, did you make sure to use a rinsed container, might it have held remnants of bleach? I did both of these blunders, and they were both head scratchers for a while.
    15K gal IG plaster pool Hayward Pro-Series Sand Filter S244T Hayward SuperPump 1HP Age: Old but "recently renovated" Mineral Springs MS10 SWCG (AquaRite ancestor) Taylor K-2006 Test kit + 1766 Salt Test Leaf eater My green to clean story: Proud owner of a glorious swamp! (LOTS of photos)
    May 2013
    Norman, Ok
    35
    Re: R-0870
    Nope, this originally happened a week and a half ago (I used my remaining 0871 drops). So I ordered new powder and 0871, finally received yesterday. Rinsed the tube with tap water and then with pool sample water, then tested the first time (old powder & new drops).
    K-2006 test kit
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Re: R-0870
    I've been using the same powder for so long it's almost black and still works perfectly. Occasionally I'll take some from a fresh batch to compare and it's always the same.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    May 2013
    Norman, Ok
    35
    Re: R-0870
    It's a mystery to me, and that's why I made this post. It was stored inside with the cap on...
    I honestly would have bet that the powdered reagent would have a out lasted the others, shelf life wise, 3x. So I'm just wondering what may have affected it like this.
    K-2006 test kit
