Thread: clear water waterway sand filter
    Jun 2014
    Chinquapin/NC
    1
    Hi I have a clear water waterway 16" sand filter.It is brand new and my problem is when I screw lid(multivalve) on it starts pouring water like lid is not on tight.I used the little wrench thing that came with it and also took a hammer and turned it alil more and still water pours from underneath lid.I even took the threaded part you screw top on and took out the screw holding it together and flipped the whole ring over and tried that,still didn't work.O ring is in and looks good,like I said it is brand new.No matter how much you tighten it you can grab top and pick it up alil.Any help would be greatly appreciated.THANKS
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: clear water waterway sand filter
    I can't help since I've never used a multiport, but I know lots of people here can help you...
