Thread: Chlorine loss due to sunlight
    Apr 2008
    Arkansas
    13
    I'm sure there is a post related to this somewhere. How much chlorine loss should I expect on 11 hours full sunlight. Numbers are FC 2.5, CC 0, TC 2.5. PH 7.7, TA 90 and CYA 25-30. These were measured late this evening after topping off Chlorine 24 hours earlier and having the full sun today.
    22K Gal double roman IG, vinyl, 300lb Crystal-Flo sand filter, 1 hp Sta-Rite pump, WF on pool side with 1.5 hp Challenger pump.
    Re: Chlorine loss due to sunlight
    It varies a great deal with the air clarity, the water temperature, and your CYA level. Roughly speaking perhaps 2/3rds of your starting FC level per day with CYA around 25-30.
    May 2014
    Clinton, Mississippi
    24
    I am pretty new so someone correct me if I am wrong but I think you should keep a higher CYA if you are in so much full sunlight. It will require a higher FC but should require less to maintain the higher FC.
    ____________________________________________________________ ___________
    15,000 gallon in ground pool with liner, Purex Triton Tagelus sand filter, Pentair Superflo 1HP.... Clinton, MS.
