Thread: Fresh Pool Startup
    May 2014
    Hillsboro, MO
    8
    Fresh Pool Startup
    I had the local pool store test the water and was told I needed shock and MA and lots of MA. I had a test kit on order they said start with 2 gallons of MA in 64oz increments.
    5:00PM
    64oz MA
    128oz Bleach
    22oz Polyquart
    5:40PM
    64oz MA
    128oz Bleach
    6:30PM
    64oz MA
    128oz Bleach
    Then my test kit showed up and here is what I got
    FC 3.2ppm
    CC 0.4ppm
    PH 7.0
    TA 250
    CH 200
    CYA 0? <--- assuming 0 as the black dot never disappeared
    So obviously I need a bit more bleach, should I take it up to Shock Levels since this is a new fill on the pool? Should I add a stabilizer to raise my CYA?
    I plan on adding some bleach tonight and retesting tomorrow.
    28ft Round AG
    20,700 gallons
    Doheny's 24 in. Filter System with 1.5 HP Pump
    New Liner and Foam Floor May 2014
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Fresh Pool Startup
    Yes, stabilizer and bleach. How does the water look? I see no reason to go to shock levels unless your FC isn't holding overnight. No reason for Polyquat. High TA isn't an issue, it only causes PH to drift up, when there are sources of aeration. So when it hits 7.8, you use acid to lower it to 7.2. Eventually the TA level will fall into a better range, since acid lowers the TA as well. Any drift you see on the PH will slow over time. They think that you need to lower the TA immediately which is why they told you so much MA. Its not that big a deal... Getting your CYA to 30-50 and the FC in range much more important. Are you going to use liquid for daily chlorination? If so I'd target 50 on the CYA.
    May 2014
    Hillsboro, MO
    8
    The pool is clear at this point, pump is up and running 24/7 until i set my timer tomorrow. The plan is to use liquid daily yes. Thanks for the advice on this, when we bought this house the pool was horribly neglected and I fought it for 2 years. Im hoping a fresh start with a new liner and new attitude will help now that ive found TFP...
    28ft Round AG
    20,700 gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    You're in good shape -- you have fresh water. It should be easy to whip that thing into shape!
    Add some CYA according to these directions. Keep the pH in line with acid and maintain adequate FC for the CYA level and really, that's about it.
    Poolmath can help you calculate the doses. Aim low on CYA. It's easy to add more if you end up short, but lowering it means draining some of your balanced water.
