Results 1 to 8 of 8
Thread: is this dead algae?
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    Question is this dead algae?
    Every morning i wake up and check my pool and at the bottom of the pool there is always this black stuff, not sure if it's just dirt or dead algae, i just currently tested my pool water and this is what i got
    FC- 3
    TCI- 3
    TA- 120
    PH- between 8.4-9 (which i know is high)
    TH-250
    CYA- 30-50
    So what is this stuff at the bottom of my pool? also when i vacuum it up with my pool blaster max all this dusty powder comes from it and makes the pool cloudy
    and this is what my pool water looks like after i vacuum, pictures dont do justice but it's cloudy...
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: is this dead algae?
    Looks like you may need to slam the pool.... Bring your pH down first, and then I would slam it... It definitely looks like algae.... And from the surface of the water, you've got lots of pollen in your area.....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    MirellaJoe's Avatar
    Jun 2013
    125
    ya i got tons of pollen it drives me friggen crazy!!! now how do i lower my ph ?
    30,420
    read "The ABC's of Pool Water Chemistry" up in Pool School....it'll tell you how to make all the adjustments.
    MirellaJoe's Avatar
    Jun 2013
    125
    ok thanks so i need to add muriatic acid to lower my ph. got that. but i'm confused on how to use the pool math i know you must think i'm dumb but i'm not sure what it means 31.45% -20degree baume?... this sounds chibberish to me, is that the strength of the muriatic acid? so if i got this correct i need to add 18 oz of 31.45% -20degree baume (muriatic acid) ? wait for the ph to be between 7.7 and 7.8 and then slam the pool and once im done slaming the pool i can add 6oz of bleach ( going by the pool math).
    Do i continue to run my sandpump filter while doing all this? and when do i turn on my SWG?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    31.45% IS 20 baume. Id' shoot a little lower down to 7.2 pre-SLAM. Only takes about 30 minutes of circulation time. Run pump/filter 24/7 until SLAM is complete. Add salt. Circulate another 24 hours...........then fire up the SWG.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Before you go through the hassle of a SLAM, do an OCLT and confirm organics before you proceed... JMHO.
    MirellaJoe's Avatar
    Jun 2013
    125
    thanks will do that
