Thread: Unsure if I should add muriatic acid
    I am still new to the pool stuff and am a little unsure about what to do. I have been having some problems with high TA and now my PH has risen also. I bought the muriatic acid, but wanted to check here before I do something I shouldn't . I have a 20,000 gallon vinyl pool. I just tested my pool here are my numbers. Please let me know what you think I should do. I know I need to add some bleach to bring it up to 4.6.
    FC 2.5
    CC 0
    TC 2.5
    PH 7.8
    TA 150
    CYA 45
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Unsure if I should add muriatic acid
    Go ahead and add the acid, use Jason's calculator (in my sig) to find out how much to add. Be careful when playing with the acid! and add the suggested amount in 2 doses, retesting after an hour between dosings. Do not add the bleach while doing the acid! You can do the bleach first and wait an hour with the system running or do the acid first and wait to add the bleach.
    All will be fine! We are here to help you 'tame' your pool
    Luv& Luk
    -Ted
    Jun 2008
    Marana, AZ
    347
    I also have a vinyl pool and add muriatic in front of the return. That way it gets dispersed right away.
    I never add more than a pint at a time, though. I have the same T/A and Ph problems you do. I don't have my T/A all the way down to 80 or whatever; it's at about 100 right now but causes no problems at that level. But if your Ph gets a little low with the adding of the acid, aerate. I was surprised at how much that caused mine to go up! No chemicals, no problems with something that might add more to the total alkalinity problem; I am so glad that I found out about that little trick on this site!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
