Results 1 to 9 of 9
Thread: William
    Jun 2014
    Pineville, LA
    2
    William
    Hello All!
    My wife and I recently bought a new home. We thought we were buying a home with a pond, but we actually bought a home with a pool – a disgustingly dirty pool. The pool is an 18’ x 36’ oval, 3’ to 8’ deep with a vinyl liner; approximately 21k gallons. And it was filled with a thick green soup covered with a nice froth and sprinkled with freshly fallen leaves. Immediately upon taking possession of our new home, I covered the pool with the heavy canvas pool cover provided by the previous owner. We have six little ones 10 and under running around, so I wanted to take the water out of the safety equation. And this is how the pool remained for three months while we settled in.
    About a month ago I contacted several local pool supply stores to inquire about cleaning and maintenance. While many of the employees were polite and helpful, the experience left me with serious concerns – mostly about my wallet. Additionally, I found that many of the people that I spoke with understood their products, but lacked an understanding of the chemistry involved. The line was, “Bring us a water sample and we will tell you what you need.” As an engineer, that doesn’t sit well with me. At my previous job I used to maintain a several electroplating baths (nickel, copper, and gold) – some fairly complicated chemistry at times. So, I figured that I should be able to manage the chemistry in a swimming pool. So I went online to search for information and that’s when I found Trouble Free Pool.
    This forum has been a huge benefit. Three weeks ago I installed a new Katch-a-Kid net and began the cleaning process. The pool had been neglected and uncovered for more than a year; possibly more than two. It is located in the shadow of numerous large trees, so there was a nice thick layer of sediment decomposing at the bottom. We purchased a new pool net, extension poles, and a leaf vacuum, and got to work. The first thing that I did was pump out half of the water while scooping out leaves and debris. The many frogs who lived in the pond/pool were none too happy. Many of them died from shock – literally. Then we refilled the pool with fresh water and continued scrubbing. We also replaced the sand in our filter and rebuilt the Hayward valve. And over the past two weeks we have shocked, settled, and vacuumed the pool twice.
    Last week I purchased a Taylor test kit and started working on the chemistry following the guidelines that I have found here on TFP. This morning’s results - FC = 4.4, CC = 0.4, pH = 7.0, TA = 140, CH = 30, and CYA = 40. And the water is crystal clear. I loosened the fitting on the pump inlet just enough so that it is sucking some air in order to aerate the pool a bit and bring up the pH. I know that’s not the best solution, but it’s what I had time for and hopefully we will be enjoying our new pool this evening.
    We have never owned or maintained a pool before. And we went from a disgusting frog pond to a beautifully clear pool in just two weeks. And TFP was my only source of information. Thanks guys! Keep up the great work.
    Cheers!
    William
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: William
    Hi, welcome to TFP! I'm glad you were able to find us and take control of your pool. A better way to aerate your water is to point a return upward so the water breaks the surface, then you don't have to purge the air out of the system. I hope you enjoy your pool!
    Love TFP? Become a
    TFP Supporter!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: William
    Hello wand welcome fellow Louisianian, it sounds like you are well on your way to having a trouble free pool
    Ike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,025
    Re: William
    Welcome!
    Since you're an engineer with chemistry background.... I'd better warn you that tolerances in pool chemistry are rather generous. You'll go crazy if you try to micromanage the readings. If you do the FAS-DPD test with the 10 ml sample, each drop is .5 ppm. That's good enough resolution for us, and it saves reagent.
    Here's an aerator experiment that should appeal to the engineer in you: http://www.troublefreepool.com/threa...thod-to-Aerate
    Or this one: http://www.troublefreepool.com/threa...imple-Aeration!
    Jun 2014
    Pineville, LA
    2
    Re: William
    Thanks Richard!
    I have been very curious about tolerances and response times. I have been testing twice a day for a week, in the am before the sun hits the pool and on the pm after the sun sets, and recording everything. Mainly to establish trends and to see how the water responds. It's actually predictable. I have a couple of little ones with platinum blond hair. And I am concerned about dyeing their hair green with my pool chemistry; actually, I am more concerned about my wife's potential reaction to a green-haired baby.
    Jul 2009
    Houston, Texas
    9,396
    Re: William
    Make sure you don't use anything with copper in it and you should be golden! (or platinum in your case!)
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: William
    Hi William and welcome to TFP
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: William
    Welcome to the forum!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: William
    As zea said it is copper compounds, often found in algaecides that cause green hair, so as long as you stay away from copper containing pool products, and you don't have high levels of copper in your fill water, that is one thing you don't have to worry about too much. Some where along the line a myth got started that green hair is caused by chlorine, this is simply not true.
    Ike
    p.s. if you are on a municipal water supply you can get a copy of their test report, which may list levels of metals found in the water (not all testing reports show this)
