Thread: DE, sand or cartridge?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    I have been studying Hydraulics 101. I noticed that a catridge filter is good for a SWCG. But sand filter is good for winterazation. But a DE is good for really clear water. So, I was interested in a DE filter but I would like to go saltwater. It will also have to be put away for winter. Am I just getting to technical in my head and over thinking? The DE with saltwater will work fine right? Thanks!
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: DE, sand or cartridge?
    Yes DE will work fine with a SWG. The issue is when you backwash, you will lose salt which will then need to be replaced. But it isn't as much as what a sand filter would be. But if you close a pool and open to an algae swamp, then I would avoid a cartridge unless you can put in a bypass.
    Mark
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Whatever you choose fit filtration will be fine. Just a matter of how fine. Is water really expensive? Sand wastes the most water and also doesn't filter quite as fine. DE has great filtration, wastes less water but you have to buy and handle DE more. Cartridges waste the least water and filter very well but more manual cleaning. I like my sand, manual chlorination for now but considering SWG in the future.
    Isolated Spa - 345 Gallons
    38,475
    If you size the DE filter large enough, you will not have to backwash very often and will thus no lose salt.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by mas985 View Post
    Good point about salt (and CYA) with a sand. Sand will change the ppm levels of those more than other options.
