Thread: Hayward H400 Heater - Combustion Blower problem
    Apr 2014
    United States
    1
    Hi,
    I have a Hayward H400IDPL2 heater; I was getting an AO error in the display. I replaced the combustion blower, ignition control board, and blower vacuum switch. When I turned on the heater, the blower started, then ignition (flame, etc); after about 2-3 minutes I heard a metallic clanking sound. The combustion blower motor had 'collapsed' and sagged down -- enough to wedge against the rotating blower wheel and stop it. It seems like there is enough 'play' in the sheet metal holding the motor that it can flex in or out (?). I'm not sure why the metal is like this as it allows the motor to sag and stop the blower. Any thoughts/ideas? Also, this is the second blower I've replaced -- same thing happened with the first one. Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Hayward H400 Heater - Combustion Blower problem
    Time for a new heater, seriously. If you replaced all of these parts you should have invested in a new unit. The model of Hayward heater is their second worst model they made. Sounds like the hood the motor mounts to has become fatigued and is too weak to support the weight of the motor once it gets heated up.
    Seriously consider a new heater before things go further south.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
