Thread: Dead Algae
    samanthamartin777's Avatar
    May 2014
    Jonesboro, AR
    19
    Dead Algae
    I believe I have won the war with the algae! I just have gray little stuff on the bottom of the pool when it settles. I've been brushing that up. Should I keep the FC at SLAM until it's all gone? FC seems to be holding pretty steady. Or should I just let it drop down to normal now that the green is all gone?
    24' round above ground pool, 13,500 gallons. Hayward cartridge filter
    30,421
    Re: Dead Algae
    The SLAM has a definitive end that you can find by reading the SLAM article in Pool School.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Dead Algae
    oh, what a beautiful avatar
    You will be done with the SLAM when you meet three criteria. See red lines in my sig
    You're done SLAMing when:
    May 2014
    Jonesboro, AR
    19
    Re: Dead Algae
    Quote Originally Posted by Butterfly View Post
    Thanks Butterfly! That's my youngest. He is 12 weeks old.
    I believe based on those criteria I am done! Thanks for your help.
