Results 1 to 8 of 8
Thread: Solar pump???
    Jul 2013
    Christiansted, St. Croix USVI
    16
    Solar pump???
    Anybody using a solar pump that really works?
    Power here in the USVI is .53/KWH and I'm think that we have plenty of sun so why not.
    8,000 gal, IG Fiberlass, Hayward DE4820 filter, Pentair Single 1.5 HP pump, Autopilot DIG-220 w/ RC 35/22 cell, Circulator returns. Tropical climate, ave. temps 85-90 degrees days 70-75 degrees nights 365.
    38,305
    Re: Solar pump???
    Why not just use your existing pool pump? That is normally the way solar systems are run.
    30,421
    Re: Solar pump???
    I think OP is inquiring about a main pump that is solar powered.
    If so, I think you will find the cost to do so excessive. Main pumps require a lot of energy that is not easily obtainable ($$$$) with solar panels.
    Re: Solar pump???
    There are specialized pumps designed to work with solar panels. However, once you price them out you will find that they cost significantly more than the price of a conventional pump plus the electricity to run it, even if your electric rates are fairly high.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar pump???
    The topic of these speciality solar pump kits comes up from time to time, but I don't know of any members that have invested in them. Generally they are DC motor powered pumps that connect directly to a solar panel, this allows the pump to run at varying speeds depending on how much light is hitting the panel, and does not have to deal with power loss converting to AC, etc.
    Ike
    p.s. there are some of these listed on ebay at the moment, price is nearly $1,500 for the smallest pump, this does not include the solar panel or wiring, specs say minimum panel output needed is 720 watts (max panel 1,000)
    Oct 2014
    Alaska
    1
    Re: Solar pump???
    Quote Originally Posted by STX Steve View Post
    Anybody using a solar pump a part of solar power system that really works?
    I got one few years back but it did not worked effectively so I removed it..
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Solar pump???
    Best thing would be to swap out the motor with a two speed and cut your energy cost by a factor of four. Shortening run time can help a lot too. Also at that rate a VS pump might make sense.
    Mark
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Solar pump???
    I saw a video on YouTube where a guy ran his vs pump with something like 5 solar panels and a couple inverters. It was running around 1150 watts I believe, and his solar system was making a little over 1200 watts. No idea how much he sank into the system, but it wasn't any kind of "kit". He assembled it all himself. So, it is possible, but would probably take a while to break even when compared to a 2 speed or vs pump running the minimum required time.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
