Thread: How to cover an intex pool for winter
    Jul 2013
    Long Island, NY
    532
    I tried covering the intex pool I had last year with a tarp and using 10 bungees with milk bottles filled with water. That didn't work well. The water pooled so badly in the middle I had to poke holes in it just to drain it so I didn't weigh down the sides. And for big snow storms of 10" I just took the cover off because I didn't want the added weight.
    Any suggestions for a 14' pool?
    I see they sell heavy duty covers but I feel like I will run into the same water pooling in the center problem.
    I saw using a tarp bungeed with cinderblocks, may do that.
    Or I saw someone suggest just leave it uncovered? I may do that and empty and refill in the spring when I'm ready to go in it. Filling my 3500 galloon pool is about $20 based on my water bill.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: How to cover an intex pool for winter
    I have a couple of cheap mesh covers I use. I ran rope in a star pattern from post to post, tightened enough to support the covers, and used water filled bleach jugs to secure the sides.
    Admittedly, tree droppings did get through the cover, so still had a bit of minor vacuuming to do when I opened.
    This method kept the mesh out of the water, and the largest debris stayed on top. Held up to 1/2" of ice followed by 6" of snow.
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    Did you put anything in the middle like an inner tube, so your cover would be tee-pee shaped? That way it would just roll off, I think?
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
