Results 1 to 15 of 15
Thread: Is it a must to have a pool vacuum cleaner & what else?
    Jul 2013
    Chandler, AZ
    43
    Hi, it has been a year since I became a pool owner. Except for first few months and ever since I found this site, I have been maintaining the pool on my own. Thanks for all your help!
    Main question I have is... I don't have any trees around (Arizona) my pool, not many in my neighbors houses too. So, leaves are not a problem. But, dust is... I have been brushing my pool every week. But, lately noticing my pool water is not clear as it was last year. Mostly noticing dust at the bottom of the pool. Must every pool owner have a pool Vacuum? My test results are all ok... except CH of about 550 now. But, I read it is normal in Arizona.
    What else am I missing? All I do is test every few days and maintain FC, PH ... every week for TA, CH, 3 times year CYA. Brush the pool and clean the baskets every week. what else should I be doing regularly? I have leaf rake but don't have to use those much.
    Thanks!
    12x40 In ground, 16K Gallons, Pentair VS pump, 420 catridge filter, 140HC Heatpump, Stonescapes pebtec surface, Chandler, Arizona
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,596
    Re: Is it a must to have a pool vacuum cleaner & what else?
    A vacuum will definitely help keep your water clearer.
    A loss of water clarity is usually a sign that the chemistry is out of balance. If you post a full set of water test results we can examine them and see if there is anything obvious going wrong.
    donniespool's Avatar
    Nov 2013
    Tucson
    31
    for what it is worth...I have not used the vacuum attachment for my pool in years...I use a Kreepy that runs when ever the pump is on..it is constantly removing anything that settles to the bottom. A vacuum is cheaper however...if you want to devote the time involved using it.........D
    in ground gunite/plaster 16x30..3-6-3 play pool, sand filter, 1 hp pump..single speed... built in 77 replastered in 05
    15300 gallons. chlorine tabs no longer...tf-100 test kit
    Jul 2013
    Chandler, AZ
    43
    Thanks for the quick responses!
    My last test results:
    FC - 4 - Added bleach to make it 7
    CC - 0
    PH - 7.6
    TA - 100 - Reduced PH to 7.2 and ran my falls to raise PH.
    CH - 550
    CYA - 60
    May be I worded it wrong. Sorry, it is not clarity. It mostly floating dust in the water. also, dust on the floor. Other factor, could be that I bought solar cover recently and started using it. Can the Solar cover make the pump inefficient by any degree? The cover is the whole time the pump is running.
    May 2014
    Turlock, CA
    55
    I have tall trees at both ends of my pool, junipers on one side, redwoods on the other. I get a lot of small leaves in the pool when the wind blows hard. I remove as much as I can with a leaf rake, and the Polaris gets the rest.
    This is my fourth season with a pool, I don't own a vacuum.
    21K gallon, plaster, 1hp Hayward MaxFlo pump, Hayward 244s sand filter, 3/4 hp Halcyon PB4-60Q booster pump, Polaris 280 cleaner.
    May 2012
    Montville NJ
    545
    A vac helps. It does not need to be an automatic vac, just the hose and head attachment for your skimmer pole will do fine. Pools get stuff in them - dust from the air, pollen, dirt that people track into it, etc.
    I have found that while my solar cover helps in keeping some dirt out, it also creates more of a need to vaccum becauseit makes the skimmer less efficent. The solar cover supresses teh circulation of water that moves any debris into the skimmer, instead it lets them settle to the bottom.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Jun 2013
    Indiana
    57
    I would think you should have some sort of vac. Heavier sand that will not stay afloat will settle on the bottom and have a hard time finding its way to the drain to get filtered out. Your pool is probably already setup to connect one, so all you would need would be the hose and a vacuum head and use your existing pole. You could probably be good to go for $75. If you want a automatic robot type vac you could spend $$$$.
    Mark
    IG plaster, 22,000 gallon, Jacuzzi Laser Sand filter
    Oct 2013
    Chapin, SC
    1,141
    Love my Polaris 280.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    30,419
    You need a vacuum. It can be a handheld that attaches to your skimmer or it can be an auto-vac but you need a vacuum.
    Don't leave that solar cover on forever.....pools like to breath. I would suggest 1 day off and two days with it on.
    Your numbers look excellent and would not suggest a chemistry problem....looks like you are keeping your chemistry in good control.
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    I agree 100%. Brushing regular is important, but sooner or later what your skimmer is not catching from the brushing is going to build up and will have to be vacuumed. I've never had a need for an auto vac but I can't imagine maintaining a pool long term without some sort of vacuum.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    Jul 2013
    Chandler, AZ
    43
    Thanks to you all! started shopping for a Vacuum head and hose (manual ones for now). Lowes has both for 60 (22 head + 38 hose).
    26venus's Avatar
    Jul 2013
    48
    my last one came from Lowe's and I'm very pleased with it so far. I've only had it for this season so time will tell.
    http://www.lowes.com/pd_102919-1003-...uum&facetInfo=
    26venus's Avatar
    Jul 2013
    48
    Oops. Sorry guys. Just tried to post a comment that included a link. That was a no-no. Anyway I was trying to visually share, via the link, what I believe is the same vac head from Lowe's (based on price). I purchased one of these early this season and I'm very happy with the performance. If a long life comes with it I'll be even happier.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by 26venus View Post
    Not a no-no at all, but for new members, posts with links require moderator approval before becoming visible in the forum.
