Results 1 to 10 of 10
Thread: No chlorine, added 3" Trichlor tabs (2), checked 2 days later, still no chlorine
    Inline feeder. I had the dial set to 3ppm. So when I checked it again this morning, the tabs were still in there (no major degradation that I could see) and the Chlorine level today at .2ppm.
    I added a couple more tabs just to fill up the canister, and dialed it to 3.5ppm today. I put my ear to it and feel like I did hear water running through it.
    Will the ppm level out in a few hours, days, or what? Am I doing anything wrong?
    TA: 110
    pH: 7.5
    ~12k gallon, cartridge filter, IG, plaster, 2hp Pentair Whisperflo WF-28, 150gpm filter
    Pics: http://imgur.com/a/HqaPq#0
    Re: No chlorine, added 3" Trichlor tabs (2), checked 2 days later, still no chlorine
    The dial on the feeder isn't marked in ppm, it is just a relative setting: more or less.
    When your CYA level is very low, as I guess yours probably is, you will lose chlorine very quickly to sunlight. When CYA is low, even setting the feeder all the way up will not maintain a very high FC level.
    Please get a full set of test results, including CYA, and we can see if I am guessing correctly or not.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I'd add a jug of bleach pronto!
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Quote Originally Posted by JasonLion View Post
    Ah, thanks for the tips on the feeder. Is it possible that the feeder wasn't circulating water? Maybe I didn't prime it correctly (it's the first time doing it).
    CH - 275
    CYA - 30
    TA: 110
    pH: 7.5
    Temp: 76
    CYA at 30 is on the low side, but not low enough to cause the effect you are describing in the way I was imagining.
    You might be right, but chances are the tablet feeder is working. They can get clogged, but that isn't all that common.
    How does your water look? If the water is clear and sparkling, odds favor some problem with the tablet feeder. While if the water is cloudy/murky odds favor algae getting started and consuming most of your chlorine.
    While you are figuring this out, you should take JesseWV's advice and add some extra chlorine manually. Using bleach is a good way to do that.
    Thanks. I had a pool company servicing this for a while, and they never had any issues with the feeder. It's crystal clear, so no problems there. Do I add just typical bleach, as in washing whites bleach? How much? 12k gallon pool approx.
    Yes, ordinary household bleach. You want the plain standard unscented kind, without any special features.
    For 12,000 gallons, 2 to 3 quarts of concentrated bleach (8.25%) or roughly a gallon of Ultra bleach (6%).
    Test the FC level again a couple of hours after adding the bleach to see if it is all vanishing or if most of it is staying around. If it all vanishes, there may be something more complex going on.
    Casey's Avatar
    SW PA
    10,442
    You can use PoolMath to determine how much bleach to add.
    Thanks. I checked again just to make sure I wasn't going nuts. It looks like it's closer to .4ppm. I will run to the store and grab some bleach to bring it to 2-3ppm.
    Quote Originally Posted by Casey View Post
    Oh! Thank you.
    I'm up to 4ppm now (thanks for the bleach suggestion) and will continue to watch it daily. Just want to really make sure the feeder maintains it for me. Thanks again for all the advice.
