Thread: Question about installing a stenner pump
    Hey everybody. Great site. I've been catching up on as much reading as I can. Not meaning to hijack the thread, but I have a question about installing a stenner pump.
    Topic split. Please don't hijack someone else's existing topic. JasonLion
    If I understand the setup correctly, it's as simple as installing the pump attached to a timer, and as long as the pump is set right it will inject a set amount of chlorine every night? I.e. My pool pump runs 7pm-7am. I could have the stenner Pump come on for a half hour every night at midnight, injecting 1/2 gallon of chlorine (or whatever the magic number may be) for my 25k gallon vinyl inground... I could adjust the timer to shock (should the need arise) or just shock manually.
    Is it really this simple?
    Using Tapatalk
    Aug 2011
    Southern California
    188
    Re: Question about installing a stenner pump
    You'll need a couple other items as well such as a tank, but yes, it is that simple. I've been using mine for almost a year and I'm totally happy with it.
    If you already have some kind of automation, that's a plus.
    22,553
    As Hawk said, it really is that simple. The hardest part is adjusting the amount of time the injection needs to run, and once that's done, you just check it daily and test the water to make sure it's keeping the FC at the proper level.
    This is awesome. My tf-100 will be in any day. Once I have a trend of how much my fc drops each day I'm definitely getting this up and running. Is Stenner the brand to go with? Would they be better than roto-chem?
    Using Tapatalk
    22,553
    There are several Rola-Chem users about and I haven't heard any complaints from them. I'd say go with whichever is more readily available to you. Or whichever you like the best.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I like the Stenner, its really good quality.... Surprisingly heavy.... Mine can do 10 gallons a day and my pool is tiny compared to yours, I will run it only for a short period of time when the pump kicks on overnight....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
