Results 1 to 12 of 12
Thread: Circupool SI-plus install
    Jul 2011
    phoenix
    133
    I have approx a 13k pool and went with the 45. And will be installing this week. I have added two bags if salt so far and will do another 2 tomorrow. Please let me know if you have any advice with the install
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Circupool SI-plus install
    Don't forget to connect the bonding lug at the bottom of the control panel to the bonding system. You will need some bare #8 copper wire and probably a split bolt connector. Make sure you have the flow switch going the right direction.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Jul 2011
    phoenix
    133
    Yeah almost forgot about the bonding wire. Picked some up along with some liquid tite to protect the wire from my dog and the blazing Phoenix sun. Evening thinking of getting a scrap piece of 90% sun screen to make a flap that will protect the screen lol
    Too much?
    Circupool SI45+ swg
    Jun 2013
    South Florida
    118
    I installed the SI30+ last week and it was straightforward. Make sure power wiring is connected to the same terminals that turn on your pump. The swg will then turn on at the same time your pump turns on.
    Nov 2007
    Yardley, PA
    17
    I likewise did my own install 2 weeks ago with the SI45+. Pretty straight forward, and yes do not forget the grounding line. I used two 4' fence posts from Lowes that I drove into the ground, and then mounted a piece of wood to the posts. Then mounted the control box to the wood, which leaves lots of air space to keep it cool.
    Only problem I have so far is a drip coming from the flow sensor plug. Company said it is a screw fitting, and suggested I take out the epoxy wire plug, add new Teflon tape and rescrew it back into the fitting. Still trying to get it dialed in, good luck.
    30,000 gallon Sylvan, Hayward 60 sq ft DE filter, IntelliBrite LED Light, Circupool SI45+ SWG, Raypak 400k BTU Propane Heater
    Jun 2013
    South Florida
    118
    Quote Originally Posted by spudman View Post
    Mine dripped as well. Must be a qc issue. The black colored sensor unscrews. Just take it out, add heavier thread tape. I also use a blue colored pipe dope (forget the brand) lightly on the threads. You can fix it in a matter of minutes.
    May 2008
    Long Island, NY
    151
    I installed a Si45 this year and I have the same drip. I emailed them about it the other day and they suggested to add more teflon tape also.
    Pool Details: 25,440 Gal IG Vinyl 21x40 Mountain Pond (Graphex)
    Filter: Hayward Micro-Clear DE (48 Sq Ft)
    Pump: Hayward SP2603VSP VS Super Pump
    SWG: Circupool Si45
    Cleaner: Pentair Kreepy Krauly Prowler 820
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Mine drips also, but only on high speed. It would take an extremely long time to drain the pool.
    Jul 2011
    phoenix
    133
    Thank you all for the info. I did end up finding the stud behind the stucco. Have two 2 1/2" screws in the middle top and bottom and the other four are just anchored into it.
    I started building the vertical assembly and half way through I noticed a crack in the slow sensor PVC housing. Called them up and they shipped me a new one no questions asked. Here is a pic of it mounted. Will clean up the wires once I get the cell in place. I used #8 copper wire for the bonding and attached it to the metal pipe that the pump is bonded to. In the timer box this metal pipe is actually the pool light wiring inside of it (did not know that)
    Circupool SI45+ swg
    Jul 2011
    phoenix
    133
    so I cut in the cell/sensor this morning and I am like a little kid waiting for the glue to dry so I can play with it. Glue always says 24hrs but with our 106 temp wondering if I can just fire it up this evening (9 hours of cure time).
    Circupool SI45+ swg
    For PVC glue, you should be fine after 30 minutes.
    Jul 2011
    phoenix
    133
    Can't a guy catch a break? Fired up the pump and what do I see a leak. But it's not on any of the new plumbing for the swg I installed but rather a hose bib hookup between the pump and filter. I must have bumped it while working and cused a crack where the bib screws in
    Last time I tried to use this with a hose I barely trickled out and took forever. So since I now need to cut out this T I replaced it with a 1.5" outlet and out a ball valve on it so I can hook up a backwash hose to drain when I need to remove some water.
    Circupool SI45+ swg
