FC-3
CC-0.5
CH- 350
TA- 110-120- instructions said it should turn red, turned pink and then a dark pink
CYA- 45- I sort of went cross-eyed doing this may need to try again
Is there not a way to get an accurate PH with this test? With the standard PH tester I am getting 8.2, which is on the high side
Do these results look OK?
Also, panel says salt is 2850, will add some this week to get back to 3400 or so
CC-0.5
CH- 350
