Results 1 to 9 of 9
Thread: Tf-100 first test results
    Jun 2013
    Dunwoody, GA
    74
    Cool Tf-100 first test results
    FC-3
    CC-0.5
    CH- 350
    TA- 110-120- instructions said it should turn red, turned pink and then a dark pink
    CYA- 45- I sort of went cross-eyed doing this may need to try again
    Is there not a way to get an accurate PH with this test? With the standard PH tester I am getting 8.2, which is on the high side
    Do these results look OK?
    Also, panel says salt is 2850, will add some this week to get back to 3400 or so
    Tallman Monterey (fiberglass), 16'x33', 11500 gallons, 480 sq/ft, Depth: 3' - 5' 6", Salt Water, TF-100, Pentair pump, sand filter, Easy Touch Control System, SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Tf-100 first test results
    What's wrong with the pH test? 8.2 is a valid number. The scale stops there, so it could be even higher if that's what you're getting. A SWG and high TA both tend to push pH up, so it makes perfect sense since you have both.
    You probably want to raise the CYA level a little, on account of the saltwater generator.
    Jun 2013
    Dunwoody, GA
    74
    Thanks Richard, so PH of 8.2 is OK or shoud bring it down? I will work on the CYA, thanks
    BTW, pool looks good, not having any issues, working to get accurate results and be able to use BBB going forward
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    8.2 is too high. Use PoolMath and Muratic Acid to lower it. Make sure you put your correct TA in the results box to get an accurate measure for acid.
    Yes - a hot magenta pink is what I would describe as the color when the TA test is done.
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by WWells View Post
    No.... 8.2 is way too high. You need to lower it with acid. It may be higher than 8.2, so after you dose it according to poolmath, it might still end up being too high. It could take two or three doses of acid to get it in the safe zone between 7.2 and 7.8.
    You made it sound like something was wrong with the test kit.
    Jun 2013
    Dunwoody, GA
    74
    Thanks all, I had some PH Down left over from pool store days, added it and will recheck around lunch time, will also get some muriatic acid
    11,969
    You shouldn't use PH Down with an SWG
    Jun 2013
    Dunwoody, GA
    74
    Quote Originally Posted by frustratedpoolmom View Post
    Well that wont be a problem going forward, I only had about 25% of what was needed so decided to use it up and clear the container
    Jun 2013
    Dunwoody, GA
    74
    well that little amount got it down to 7.8, will keep an eye on it
    I am now have 2 gallons of muriatic acid
