Thread: Intex SWG stops generating during run cycle
    May 2014
    St Louis, MO
    37
    I have the Intex SWG set to run 9 hours at night. When it starts, all the correct lights are on and I can see the chlorine being generated. I have checked the unit with 2 hours remaining in the cycle, and can't see chlorine in the generator. Pump and filter are working, correct lights are on. If I push the lock/unlock button, as to change run time, then push lock/unlock again it begins generating chlorine again. Also, the cells have just been cleaned. How do I fix issue? Thanks
    24'x52" AGP 13,200 Gal Hayward Sand Filter w/ Matrix 2 speed pump Liquidator Taylor K-2006 Test Kit
    Sep 2015
    Rancho Cucamonga, CA
    53
    Re: Intex SWG stops generating during run cycle
    Did you ever resolve this problem? I believe I'm experiencing the same with the same model combo pump filter SWG.
    Intex Ultra Frame AG Round 16'x48", 5050 gallons
    Intex 28651EG Sand Filter Pump (had SWG, still have salt in water)
    Intex Auto Pool Cleaner, Intex Wall Mount Skimmer, Intex LED Pool Sprayer
