Results 1 to 10 of 10
Thread: Replacing Sand with Glass Beads (Pearls)
    Hi,
    I want to replace the Sand in my Waterco Sand Filter with Glass Pearls / Beads as this is supposed to offer better filtration and a much longer service life.
    Does anyone know if I need to replace the same weight in Glass or use more/less of the beads?
    Thanks
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Replacing Sand with Glass Beads (Pearls)
    One of the manufacturers of glass filter media recommends same weight.
    By the way, I think you should be using crushed glass media, not glass beads. Glass beads are for metal finishing and won't work in filters. The glass you want is crushed glass specifically made for filters.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    In the collective experience of the forum, nothing works markedly better than plain old sand. If you want to catch some finer stuff that you think might be getting through the filter, you could always try adding a little DE.
    We have had a number of people reporting problems with glass media. Sand is just about ideal and never needs to be changed.
    May 2014
    Montpelier, Virginia
    54
    Sand in my filter has not been changed in 38 years and it works like a champ!
    40,000 gallon, vinyl liner, sand filter, oldie but goodie, Chef for all your cooking questions!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I also had a poor experience with glass but at the time I didn't know any better and the pool store I dealt with only sold glass. A little wiser now because of TFP, have completely ditched the pool store and I sourced #20 Filter sand from the local masonry supply and have no reason to ever change.
    May 2013
    North East Ohio
    959
    RUN RUN RUN from Glass Media in your sand filter! FAST AS YOU CAN!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Thanks for your replies!
    I somehow didn't get notifications to this thread and missed all the replies.
    In the meantime, I've gone ahead and changed the Sand with 0.8mm Glass Beads made for filtration after discussions with the people at Waterco. I used a generic brand of glass beads since Waterco isn't available in my area.
    Hope I haven't made a huge mistake!
    Guess I'll learn soon enough..
    May 2013
    North East Ohio
    959
    Quote Originally Posted by manjy View Post
    In my opinion it all depends on what pumps and pressures you can run...if you have a 2 speed and run really low filter pressure I bet this will not work.
    Quote Originally Posted by toofast View Post
    Hi, I have a single speed 2.5HP Waterco Suptauf Pump. This one to be exact:
    http://www.waterco.com.au/component/...-pumps/supatuf.
    The working pressure was about 10 PSI.
    I use borewell water which always turns reddish brown after the addition of Chlorine. It normally used to take 2-3 days of filtering and vacuuming to get rid of the Iron that had suspended out. This time I ran the filter for about 12 hours, added some alum to the overflow drain and used my robot once and the pool was sparkling clear. No idea if it was the Glass Beads, the reduced water volume (pool renovated recently and volume reduced by about 5000 gal.) or just pure luck! I did a backwash and the water that came out was a deep red.
    My PH was a bit high (7.8) so I haven't added the Borax yet. This will be the first time I'm adding Borax, which I will do tonight after getting the PH down a bit.
    14000 Gal. Inground Overflow Pool with DIY Sheer Waterfall Return. Norman Robotic Pool Cleaner.
    TechnoPool PH Acid Doser. DIY Chlorine Doser. Waterco 2.5HP Pump/Filter with Glass Media (0.8mm Glass Beads).
