Results 1 to 7 of 7
Thread: A bit confused
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    A bit confused
    FC 1.6
    PH 7.0
    TA 130
    Has been great for a week. When I left this morning at 7AM all was great. Not sure what happened. Did do some digging in yard and there is dust on bottom of pool. Maybe that's why? Or sunlight stronger today.
    I added 24oz of liquid bleach at 8.25% and 24oz of borax.
    Am I on the right track. I do need to vacuum but waiting for part on order.
    Intex 15'x4' round AG metal frame pool, 4400 Gallon, Krystal 14" 2150GPH Sand pump/filter .75HP. Taylor 2006 test kit. San Diego, CA.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: A bit confused
    do you know your CYA level and how was the testing done?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: A bit confused
    Salt water pool? What is your cya level?
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    Re: A bit confused
    Cya 30
    Not a saltwater pool
    Using Taylor 2006
    Also, that TA at 130-should I be all over that with baking soda to get it under 100?
    Can't be certain how much time water was under 2PPM, at least a couple hours probably, not longer than that. Hope algae doesn't grow that quick.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: A bit confused
    Quote Originally Posted by jamesd8 View Post
    Cya 30
    Using Taylor 2006
    Baking soda will raise the TA. Don't add any.
    You might want to reread a few pool school articles. They'll make more sense now that you're doing the daily testing thing.
    http://www.troublefreepool.com/conte...ater-chemistry
    http://www.troublefreepool.com/conte...pool-chemicals
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    Re: A bit confused
    I used pool calculator and put in now and goal for TA and it was telling me to add baking soda. Either the calculator was having a moment of confusion or I mis keyed the numbers (probably me). Thanks, I will review links to those.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: A bit confused
    TA is the last thing you should worry about in balancing a pool, almost something to do as an afterthought or when everything else is perfect and you are bored
