Results 1 to 19 of 19
Thread: Intex 56671EG 2,650-Gallon Sand: Start up question
    Here's a 'softball' of a question: Is there something I need to do in order to 'prime' my sand filter pump every time I start it up? The reason I ask is because it seems to take a significant amount of time to start suctioning/cycling the water through each time I power it up. Most of the time I end up removing the clear plastic lid (on the pump intake basket) in order to get it to fill up a bit faster and to start pumping. Is this normal??? I have a feeling if I never "helped it along" it would just continue to run, but not cycle. Again, once it gets going, it's golden! This is only it's 2nd season of use (and the 1st season it barely ran at all) so I believe it's still in great condition.
    Any feedback would be much appreciated!!
    Thanks!
    Jun 2013
    Fallsburg, NY
    258
    Re: Intex 56671EG 2,650-Gallon Sand: Start up question
    We'll need to know a little bit more about how you have it hooked up to answer that question. The intex pump and filter are self priming as long as they are below the level of the water.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Quote Originally Posted by PridgNYC View Post
    Here's a couple of pics of how it's hooked up. Again, there's once in a great while where I'll start it and the cycle starts immediately. But more often than not, it takes quite a long time for the water to really start kickin through the filter. ("Kickin'" is a technical term)image.jpgimage.jpg
    Jun 2014
    Toronto, ON, Canada
    98
    I experienced the same thing with my new 2800GPH sand filter pump. Seems after it runs the filter basket loses a lot of it's water. Doesn't seem to occur every time. But when it does it takes awhile for the basket to fill with water again. As it fills, the water flow increases gradually.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    When you pull the clear plastic top off of the pump basket does water immediately stark gushing out of the basket area and pouring everywhere and spray as you quickly try to get the lid back on? If it does then I cant explain your problem.
    One area I would check is the suction side, on the inside of the Intex pool. unscrew the hose adapter off of the outlet and check the grid. That grid is infamous for getting really gunked over with leaves and debris.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Mid Missouri
    227
    I always manually bleed as much air from the system as I can prior to an initial startup. By unscrewing the cap and even tilting my SWG and working that air pocket out of the return. It clears the little bit of air left pretty quickly. I don't get any other significant air in the system during normal cycling unless I do something to cause it.
    Jun 2014
    Toronto, ON, Canada
    98
    I have the pump on a timer so I'm not there to manually bleed out the air. But the pump does self prime so it's not a problem.
    12' Intex Metal Frame Pool, 1500 gallons, Intex 2800gph Sand filter/pump, AquaPro PRO1100 HP, K-2006 Test Kit
    Mid Missouri
    227
    Quote Originally Posted by crimsondr View Post
    You shouldn't be getting any significant air in the filter basket between cycles. After it clears the air on the initial cycle it should stay that way.
    Oct 2012
    Houston, TX
    186
    I agree with ranger rick.
    Also I am wondering if perhaps there is a problem with your suction side new-style Intex valve. It there is the typical obstruction (or just a problem with the valve in general) that may be causing the safety relief to suck in air. That's been mentioned alot regarding these valves.
    First check for the grid blockage ric mentioned. Then put the clear cap onto the nipple next to the open/close knob on the valve. See if that helps.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Jun 2014
    Toronto, ON, Canada
    98
    Looks like my pump is sucking air from the knob. Unfortunately I can't find the plastic caps. Any suggestions on how I can plug the knob?
    Mid Missouri
    227
    Did you check to see if there was any restriction causing it to pull air thru the valve?
    It looks like they may unscrew. You could switch the two if that's the case. I used to put tape over mine when I vacuumed, til I realized there was supposed to be caps and found them in the box I saved. Or maybe silicon?
    Quote Originally Posted by jcp View Post
    By knob I assumed you meant relief valve, disregard if you meant another part.
    Jun 2014
    Toronto, ON, Canada
    98
    Yes I meant the relief valve. I don't have the caps. What do you mean switch them? Get another cover.
    Jun 2014
    Toronto, ON, Canada
    98
    I also did check and there was no obstruction.
    Mid Missouri
    227
    I meant switch the one from your suction side to the return side. It looks they may just unscrew, but I don't know.
    Jun 2014
    Toronto, ON, Canada
    98
    Yes, they just unscrew. I'm not sure what switching the caps would do. They're both new valves so probably function the same. At the moment I placed a piece of saran wrap under the cap and screwed it back on. That seems to be working for now. Not sure if it'll leak but we'll see.
    Mid Missouri
    227
    Uh ok.
    Jun 2014
    Toronto, ON, Canada
    98
    Uh ok.
    Is that a bad idea? I may just remove the valve and connect the hose directly to the pool to help improve water flow and eliminate the problem of the relief valve.
    Oct 2012
    Houston, TX
    186
    I didn't think it was, at least as a test. Most anything that will plug it up should be fine.
    Removing your valve is ok if you don't mind losing the ability to shut off water so that you can maintain the pump/filter or stop a partial drain due to a split/cracked/hole in your hose. Those new valves allegedly have better flow than the plunger-style valves it replaced.
    Mid Missouri
    227
    If the root cause of the problem is a defective relief valve, and you have another new relief valve 5 feet away, it seems logical to try the other relief valve if they are easily interchangeable. I would think the odds of having two defective relief valves would be low. If the one currently on the suction side is defective it wouldn't matter on the return side.
    I don't think the relief valve should be allowing air in under normal correct operation.
