Results 1 to 8 of 8
Thread: New to pools and lost on what chemicals to add
    Jun 2014
    Atlanta, ga
    26
    I need soooo much help. I just purchased a home with a pool. I've never owned a pool. I just ordered my test kit TF100. My chlorine level seems really high and my CYA does as well. I'm a little worried at this point. What do I do? Here are my test results.
    FC - free chlorine 8.5 ppm
    CC = Combined Chloramines 1
    TC= total chlorine 9.5
    PH 7.5
    TA - Total alkalinty 130
    CH - calcium hardness 250 ppm
    CYA - cyanuric acid...aka stabilizer/conditioner 100 plus maybe 140
    18K gal, IG Gunite, Sand Filter, TF-100 test kit
    Re: New to pools and lost on what chemicals to add
    Welcome to TFP!
    Assuming CYA is 140, the minimum FC level is 11, so don't worry about your FC level being too high. FC is either too low or just marginally acceptable (depending on the actual CYA level).
    The high CYA level is a significant problem. I strongly recommend replacing water to get CYA down to around 60.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Welcome to the forum. You are soooooooo far ahead of most by already ordering a GREAT test kit. If your cya is truly that high, you'll have to replace water. Drain and refill say a third at a time. Retest after circulating awhile after refill to make sure new is well mixed in. CC of 1 isn't good and you'll need to wait on the kit to do a proper SLAM on it.
    Jun 2014
    Atlanta, ga
    26
    Thanks for your help. It is what it is. I had a feeling that I had to drain some of it. What causes a high CYA? This way a learn what not to do. I hope I have the pool ready for a birthday party 5 days from today
    Jun 2014
    Atlanta, ga
    26
    Never mind replying to my last post. I searched for high CYA and found my answer. Thanks again. The test kit worked great by the way! I've never used one before.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you have a party coming up I would certainly start draining and refilling right away, just remember refilling tends to go a lot slower. Depending on your soil conditions it can be dangerous to fully drain a pool as it can "float" out of the ground if you have a high water table. Unless you live in a very wet soil location draining 2-3 feet at a time should be safe, although it is best not to expose the bottom.
    Ike
    Jun 2014
    Atlanta, ga
    26
    Thanks Isaac. I guess I should drain 1/3 of the pool. Is that correct?
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Were the test results in your first post from your TF-100 kit?
    If so, did you do the dilution test for your CYA since it is over 100? It involves diluting your pool water 50/50 with tap water then using that to test. You multiply the results x 2. That way you can find out how much over 100 you are and get a good idea of how much total water you have to replace. You'll still do it in stages.
    http://www.troublefreepool.com/threa...Kit-Directions Post #8 explains the dilution test for figuring out CYA over 100.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
