Results 1 to 8 of 8
Thread: AGP Oval Install Level, 1 inch off, use sand to fix?
    Jun 2014
    Harker Heights
    7
    I'm doing a one man install. I've got my area within a 1.5 inches of level. The pool will be 24 inches below ground at the highest, 34 at the lowest. I haven't leveled/installed any paver's yet, but I'm not far. I'm in central texas and hit caliche clay where it's at...hard as **** right now.
    I'm not sure why this post went ****, I said "a rock" not bad language at all..
    1. Can I use sand to finish leveling this bad boy off since it's below ground
    2. Should I wait to get everything together then do that (if ya'll answer yes to question one).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,657
    Re: AGP Oval Install Level, 1 inch off, use sand to fix?
    I'll say this. Mine is buried 2 feet. Low and behold like the day after it was installed, filled, and back filled, a nice rain washed out a spot you can stick your foot into about an inch deep. I'll fix that if I ever need to replace the liner.
    Casey's Avatar
    SW PA
    10,461
    Sand is terrible at filling in and leveling. You need a solid base, whether it's clay or crusher. At least with the crush, you can add and compact it and it won't wash out like sand.
    Jun 2014
    Harker Heights
    7
    I have to worry about washout with it being two feet deep and backfield with dirt?
    Apr 2010
    East Texas
    9,657
    I didn't, and I got one (divot) so you tell me! Takes a long time for that dirt to settle and pack in. I added more at least twice that summer.
    Apr 2014
    Gardners, PA
    69
    Like Casey said if you do fill in anyting use crusher. It packs like cement. At least here in PA its easy to get.
    30' round Swip N Play Islamorada above ground pool with Hayward Pro Series 220T sand filter, 1HP Hayward Super pump, and Hayward SWG.
    May 2009
    Mn
    198
    Our pool was incorrectly installed on sand...yes even though it was buried, the sand shifted. It is better to take the time for a solid foundation than taking the easy way. It won't be easy to fix later.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Jun 2014
    Harker Heights
    7
    Thanks for the response. Crusher it is...
