Results 1 to 9 of 9
Thread: Searched high and low for this fitting and STILL cannot find it! HELP PLEASE!
    Jan 2014
    Fredericton, NB, Canada
    130
    Hi Guys...in the middle of my first ever inground pool install (couple updates in the "under construction" forum) and have ran into a seemingly small problem that I can't seem to properly solve... After alot of discussion on this site and elsewhere, I decided to go against my online pool supplier's advice of using 1.5" flex for my pool plumbing and insisted on upgrading to 2" flex. I was very happy with my decision and my pump, filter, and heat pump all have 2" fittings...more proof that I made the right decision. But today when putting in the main drains, I realized that the drain fittings, returns, and skimmer are all 1.5" female threaded. No biggy, I figured I'd just run down the road and pick up an adapter from 1.5" male threaded to 2" barbed for my 2" flex. Apparently that's not so simple. I literally spent the whole morning trying every pool store, hardware store, plumbing warehouse and pump service place in my whole city with no luck. Not one place had such a thing. One place did tell me they could order it but it was a minimum $75 order fee...when all I needed was $12 worth of parts. Does anyone have an online website they can recommend that would sell what I'm looking for (with very fast shipping?)
    In the meantime, what I did find was a 1.5" male threaded to a 2" smooth slip fitting and just glued the 2" flex into it. Local pool guys says it'll work fine, but my installer feels alot better about using a barbed fitting, then gluing and clamping it...
    Thanks in advance!
    18' x 36' IG Vinyl Kidney Shape, 20K Gallon, Hayward ProLogic PLP4 Control with T-15 SWG, ColorLogic 4.0 LED Light, Hayward TriStar 1 HP Full Rated Pump, Hayward Swimclear 325 SQ FT Cartridge Filter, Raypak 117000 BTU Heat Pump, TF100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Searched high and low for this fitting and STILL cannot find it! HELP PLEASE!
    Flex PVC or polyethylene (PEX)
    I believe flex PVC just glues up to regular PVC fittings.
    PS: I was right! Check out this: http://flexpvc.com/faq.shtml
    FlexPVC gets glued, poly gets barbed fittings and clamps. It doesn't work the other way around, FlexPVC will never seal properly to barbed fittings, and poly won't glue properly. Both kinds of incorrect connections will leak and/or fail.
    Jan 2014
    130
    Thanks guys!...Makes me feel alot better about the method we used. The hose is 2" Tigerflex... I'm pretty sure that's flex pvc... So it sounds like it should work great. We are pouring the hopper, footings and slabs for my shed and heat pump this morning! Progress is being made!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    If this is what your builder is using STOP! That is not flex pvc! Everything I searched called Tigerflexbrought up this clear polyurethane hose that is not for in ground plumbing.
    Flex PVC is rated schedule 40 for pressurized plumbing applications and can be buried or used above ground. It is very firm, but has some flex to it. It is white with small ridges spiraled along the length.
    Love TFP? Become a
    TFP Supporter!
    Apr 2013
    North OKC Area
    300
    It looks like they make the correct type hose as well. http://www.plastixs.com/tiger_spa.html
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by DanielP View Post
    Well, if that's what they used, you're in luck. Your linked page says,
    • Designed to be glued into Schedule 40 PVC fittings
    Jan 2014
    130
    It's definitely the second stuff...flex pvc, all white, made for inground pools. I bought it from poolsuppliescanada.ca and they sell it at all my local pool stores...just charge an arm and a leg for it around here! Thanks so much for the advice though, much appreciated as always! ...Today we just finished pouring the hopper, footing, and slabs! Exciting day to have behind me! Gonna post an update in my thread in "under construction" with some pics...
    Jul 2009
    Houston, Texas
    9,376
    Good to know you have the right flex pipe! The flex pvc glues to the smooth, rigid pvc fittings very nicely.
    Love TFP? Become a
    TFP Supporter!
