Thread: Water Results.... Where to go from here?
    cabinmoose's Avatar
    Jun 2014
    Forest Hill, MD
    5
    38,000 gallon pool
    Free Chlorine 0.07
    Total Chlorine 0.14
    Combined Chlorine 0.07
    pH 7.5
    Hardness 94
    Alkalinity 68
    Cyanuric Acid 4
    Copper 0.1
    Iron 0.2
    Borate 0
    Salt 1030
    I knew everything would be low as we added 15,000 gallons of water after we had to drain it down to fix a leak.
    I know we need a lot. Pool is slightly cloudy right now.
    Thanks in advance.
    Mar 2014
    Las Vegas
    288
    Re: Water Results.... Where to go from here?
    The results you posted look suspiciously like pool store results which tend to be inaccurate. I encourage you to order the TF-100 with Speed Stir so you can get accurate and repeatable test results. Since your pool is cloudy, I suspect you will need to SLAM the pool.
    Post your results once you have the test kit and the experts here will point you in the right direction.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    cabinmoose's Avatar
    Jun 2014
    Forest Hill, MD
    5
    Yes they are pool store results. Will order the kit! Thanks so much!
    30,432
    cabinmoose,
    read "The ABC's of Pool Water Chemistry" up in Pool School. You need a basic background so you will understand why you are making the adjustments that will be suggested to you. We don't want to fix your pool....we want to help you fix it so you will have that knowledge forever.
    Oct 2013
    Chapin, SC
    1,141
    If I were you, I'd put in about 8 lbs of cya to start, that should get you to around 30 ppm (that should do until you get tour test kit) and pour in 283 ozs of 8.25% unscented PLAIN bleach.that should get you up to about 5 ppm FC. You can get both with one stop at Wal-Mart. It would be good for you to put all your pool details, equipment etc. In your signature.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
