Thread: What CYA level should I be shooting for?
    Just put up a 12 x 22 x 52 HydroForce rectangular pool and had it filled yesterday from a city water supply truck. I'm not sure what the volume of the pool is. Retailer says it holds 7725 gallons and pool calculator says it holds 8300 gallons. Truck guy had no clue. Just that he needed to come twice.
    I've already filled a sock with CYA and hung it on the return, but I'm not sure what level I should be going for. Pool calculator says 40, but we live on a farm field and have sun ALL DAY. I'm just wondering if I should go a little higher. Using pool store bulk chlorine.
    TIA for any advice
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: What CYA level should I be shooting for?
    If you targeted 40, test it again in about a week after its all dissolved and see where your at. When you determined the gallons - what did you put as the depth? That could be why you got a higher number - the water doesn't go all the way to the top...
    It's filled up to here: Pool depth.jpg
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    here is a link to the recommended levels.
    Vinyl Pool using Liquid Chlorine
    CYA = 30- 50
    http://www.troublefreepool.com/conte...mmended-levels
    have fun!
    Divin Dave,
    Thanks! I may go with 50 just to save on chlorine costs
