Results 1 to 18 of 18
Thread: INTEX 16x32x52 OWNERS any advise??????
    tmwjmw's Avatar
    May 2014
    Hoboken GA
    11
    We just ordered our new Intex pool 16x32x52. We have an 18ft round at the moment. For our current pool we had a pro level it and just used tarping under it and cement blocks for the legs and not one single issue. With this larger pool i am so excited and a little scared to be honest. Any advise from current rectanglar pool owners is appreciated. We have a 2650 sand pump, salt water system, and a Hayward skimmer ready to install on the new pool. I do plan to hire someone to level and actually a few inches further down being its a few inches taller so our deck will butt up to it better. Also if anyone could share their after install landscaping that would be greatly appreciated too.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: INTEX 16x32x52 OWNERS any advise??????
    G'day , I have the 18 x 9 x 52" rectangle pool... Congratulations on your new pool.... I love mine... We are in the process of levelling it ourselves. The one big thing about your pool you need to understand is your pool is going to weigh 54 tonnes.... That's A LOT of weight, so the legs need to be supported.... My pool will weigh 17 tonnes so I've decided to go with railway sleepers to go underneath my legs... Dimensions are 3 metres long, 20cm wide and 75mm thick....
    Enjoy setting up your new pool, you're going to love it as much as your last....
    I'm doing a slow install as my summer isn't until November...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    tmwjmw's Avatar
    May 2014
    Hoboken GA
    11
    Lacy I was reading your build earlier. Looks great. We are having someone do that. Lucky for me a customer offered. I used pavers last time that worked for leveling. I hate you can feel them under the liner. This shouldn't be an issue since this is rectangular and not oval. Are you doing and foam or pad? We didn't last time and are debating on this build.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I'm using the 30mm foam boards, on top of compacted "crush and run" I believe the US call it.... I can get the foam board sheets $10.77 Each.... I only need 11
    Casey's Avatar
    SW PA
    10,446
    I would suggest, that if you're going to use pavers, you get very thick ones. These Intex rectangular pools are snapping 1 inch thick pavers in half from the weight.
    tmwjmw's Avatar
    May 2014
    Hoboken GA
    11
    I believe my pavers are the 2" or at least 1.5 from lowes. I am so nervous about such a larger pool to level. I have looked into foam boards and my lowes only carries a 2" board. Is this overkill?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Hi there, I don't think you understand the concept of how heavy your pool is going to be.... 2 inch pavers will snap like a twig, your pool is going to weigh 54 tonnes.... That's 54 elephants...... You'll need something thicker to support the weight.....
    And no its not over kill... I've chosen 30mm thickness...
    Jun 2014
    Orlando, FL
    7
    Quote Originally Posted by Casey View Post
    That is the truth! We just installed the 24X12X52 on those 1.5" thick pads and 4 of them broke in half from the weight. We had to entirely drain the pool and put in 4" trailer pads to hold the weight.
    Intex ultra frame vinyl AG 12X24X52, 8403 gallons Intex sand/SWG filter @ 1600 GPH. Sanitizer output 7 grams per hour. SW system 0.9A, Filter Pump 3A. Installed 06/01/2014.
    tmwjmw's Avatar
    May 2014
    Hoboken GA
    11
    Ok so we visited our local lowes and i have done MORE reading and research based on ya'lls input. What about this, I found 16x16x4 concrete pads. If I use those and make a total surround of the perimeter of the pool and then fill the base that the liner will set on with mason sand and level the sand/pavers at the the exact same level should this work? Are those pads big and thick enough?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    4 inches should do the job.... You might want to look at foam underneath your pool instead of sand... Sand has a tendency to wash away as it can behave like a liquid They're a little bit more expensive, but it will last for ever and makes it very nice underfoot in the pool....
    Casey's Avatar
    SW PA
    10,446
    You will fair much better with the 4" thick pavers. We've seen too many members upset when their rectangular Intex pools snapped pavers after filling.
    +1 on the foam. Sand is just not a suitable base, especially for the Intex Pools. It's different when the sand is contained within the wall of a pool, but in the case of the Intex pool, it is not being contained and can wash out.
    tmwjmw's Avatar
    May 2014
    Hoboken GA
    11
    We have decided no go for sand and my only problem with foam is my husband says after a couple years with that much weight foam will flatten. We leave up our pool year round and don't want to tear it down to replace foam. Has anyone used padding like they use underneath carpet? I saw that in lowes and thought hmmmm???? Any thoughts on that? Foam is going to eventually flatten but this padding is made to be walked on for years.
    Tammy & Jim
    Kids, 22,19,18,14,14,14,&8
    Currently 18Ft Intex, Soon to Install new 16x32x52, Intex 2650 Sand Filter, SWG, Hayward Skimmer.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Its supposed to flatten... Its there for that reason, designed to be crushed.... It just to make it a little softer underfoot... And better than a gorilla pad.... There's not many things on the planet that wont be squashed by 54 tonnes of water.... Reassure your hubby its ok if that happens.... You're not supposed to have a soft spongy floor, it just meant to feel nice....
    And yes I used carpet underlay just this summer gone... Its gets wet, and mouldy My pool was smaller last year, it only weighed 9 tonnes, and the underlay was crushed so fast, you could barely feel it under the pool.....
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    I would use the foam. You would be surprised how low the ground pressure is under the floor of the pool. The legs on the rectangular pools, however, are a different story. They will have a much higher ground pressure than the pool floor. Definitely go with the 16*16*4 pavers.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    May 2014
    Owen Sound, ON
    44
    Has anyone with a rectangular Intex poured a cement base for the legs? I am really at a loss about what to put under these legs?
    tmwjmw's Avatar
    May 2014
    Hoboken GA
    11
    PJ, we talked to a pool builder about our pool construction on Saturday. My husband asked him about just doing a concrete pad under the pool. His reply to us was total over kill. He suggested we use mason sand and the 4" paver and we'd be fine. I tend to agree because he's a engineer he should know what is best for the construction of a pool. So at this point we are going with is suggestion. My build will be delivered on June 13th so we still planning when to put it up. I am even having second thoughts about tearing down the 18x48 until the end of the season. It's just perfectly level and no problems at all with it. I may just hold off till spring next year so we are not rushed at all. It's just been so darn pretty here in s.e. georgia it's so nice to go home to our new deck and pool. The thought of having to start new construction and tearing up the yard, plumbing, adding more deck and more electrical during the season when we want to use it kinda has be thinking just to wait.
    Tammy & Jim
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Quote Originally Posted by tmwjmw View Post
    We have mason sand under our 20' X 52" Intex. If you go with mason sand, make sure you have a way to contain it. It WILL wash out if you don't. If I would have had more time and monetary resources I would have definitely used foam board.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    If he's suggesting sand under an intex pool with no frame to hold the sand in place, he doesn't sound like he's installed many intex pools.... Where will the sand go when it rains? It will channel and pool and take the sand with it. That doesn't happen with regular round or oval AGP's as the sand is contained within the walls..... Intex pools have nothing to contain the sand as the liner stands alone with a support frame.....
