Thread: Polaris hookup question
    May 2014
    Nashville tn
    13
    Well I figure someone out there had this same setup as I did and had to figure this out. When I bought my pool it came with a Polaris 65 and it has a universal adapter fitting. My problem is I have a light on my top return so I can't hook it up there. My bottom return has an eyeball in it which I can remove, but I don't know if I want to. Plus if I use the bottom return I have to jump in to hook up the polaris. So do I modify the plumping outside and add a T to allow for a hookup? If anybody solved this I would appreciate your comments and most of all pictures. Thanks in advance.
    Jared
    24 foot 52" above ground pool using BBB method, Cartridge filter, 1.5 hp pump, new to me in May 2014
    May 2014
    Nashville tn
    13
    Re: Polaris hookup question
    Any takers on the question above...I am manually sweeping, but we are in for some bad storms tonight and it's killing me to have the polaris just sitting there.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Can't you just remove the light when you don't need it and plug in the vac?
