Thread: Way Low Ph- Very HIGH TA
    Jul 2007
    SW Indiana
    10
    This is our first year opening a pool. I bought a Taylor Test kit and after testing the water, the PH test turned highlighter yellow and the TA test immediately turned red without adding any additional drops. I have my pool running with the jet aimed up, but I only have one. I cant' raise my PH without raising my TA. How do I figure out how much products to add when the numbers are so off the charts? Can I dilute the pool water with distilled water? Can someone please tell me what I need to take care of first?
    Thank you,
    K
    21'x 52" round Vogue pool, 1 1/2 HP Sta-Rite pump, Crystal-Flo sand filter & Polaris Turbo Turtle
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Re: Way Low Ph- Very HIGH TA
    I'm confused...red TA test immediately indicates zero TA, right?
    http://www.troublefreepool.com/threa...l=1#post203522
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    30,432
    Yeah, but freqz has the answer...your TA is super low, so do this.
    1. Using baking soda and PoolMath, add enough baking soda to get your TA to 60 ppm or so.
    2. Once your TA test returns something around that 60 mark, then use 20 Mule team Borax to raise your pH up to around 7.4. Use PoolMath again and assume your starting pH is around 6.8.
    That should get you pretty close to the ranges established in "The ABC's of Pool Water Chemistry" up in Pool School
    Jul 2007
    SW Indiana
    10
    Quote Originally Posted by freqz View Post
    OH my, you are right...good thing I didn't start dumping chemicals in. Thanks for your help!
    Jul 2007
    SW Indiana
    10
    Will do, thank you for taking the time to set me on the right path.
    K
