Thread: CH Substitute - Vaporizer. Is it ok to use in Pool?
    Nov 2007
    Yardley, PA
    17
    Infrequent poster here since almost every question has been asked in the past. That's what a search function is for, so thanks to all of the Mod's and answer guys.
    I need to raise my CH from 150 to 250 in my 30k inground plaster pool. CH dropped likely due to water turnover during the winter. Anyway, looking for a substitute, I grabbed a bag of Vaporizer Ice Melt from my local Auto Parts store ($9 for a 40lb bag - score).
    The MSDS has the following:
    [IMG][/IMG]
    Is it safe to use this stuff in my pool? I suspect that it is a mix of Calcium and salt. Funny thing is yesterday I added 550lb of salt getting ready to start my SWG. Salt level was 3500 this morning so it appears I have a little room to play. Pool math indicates I need 25lbs to get to the 250 level.
    If not well I have a start on next years salt supply for the driveway.
    30,000 gallon Sylvan, Hayward 60 sq ft DE filter, IntelliBrite LED Light, Circupool SI45+ SWG, Raypak 400k BTU Propane Heater
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: CH Substitute - Vaporizer. Is it ok to use in Pool?
    Well it looks like it is about 90% salt, I think would probably be better off with something else to raise CH.
    Ike
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    It looks like there's plenty of Home Depots in your area. They have 50 lb bags of Calcium Chloride flake for $17.97.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
