Results 1 to 14 of 14
Thread: Better look at my pool
    May 2014
    Oro Valley, AZ
    120
    Deleted since the thread got hijacked.
    Gil
    In-ground: 20,600 gallons; Sand Filter 1HP pump; Kreepy Krauler; Solar Breeze Solar Powered Robotic Skimmer; TFT-100 test kit
    38,394
    Re: Better look at my pool
    Ugh ... what a mess. At least the car did not end up in the water like some people have posted. A few bricks should not affect the water chemistry, but a bunch of oil and gasoline in the water can not be fun to deal with.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my personal experience it is not so much the oil and gasoline, but the bumper going through the floor of the pool that is the big problem.
    Ike
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Ike wins!
    Casey's Avatar
    SW PA
    10,452
    Oh my goodness!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Quote Originally Posted by Isaac-1 View Post
    Ike
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I guess now that it's been a few years it's okay to laugh about it. I bet that was stressful. (I fear in time I will experience a similar situation.)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    +1
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sorry did not get pictures, getting the Kawasaki Mule out of the pool was the priority, I can show you pictures of the scrape marks left on the coping though, but first a lunch break, then I will dig them up.
    Ike
    p.s. here goes the picture and the story:
    The story goes like this, the Kawasaki Mule which was normally parked just outside the french doors seen on the right of the photo, it had just been returned from the shop, where someone forgot to re-install a return spring on the throttle, so while parking it hitting the brakes did almost nothing, it then went through the doors, it just barely cleared by a fraction of an inch (it it had been an inch to either side the door frame would have stopped it), popping the doors off their hinges, but surprisingly did not break any of the glass panes or the wood (sheered the hinge plates). As you can see in the photo the doors are offset slightly from the end of the pool, so that the left wheels on the Mule went into the water on the shallow end and the right wheels stayed on the decking. If you look carefully at the coping you can see part of the scuff mark left from the undercarriage of the Mule as it flipped onto its left side in the Shallow end of the pool. This happened about 15 years ago or so before everyone had a digital camera with them at all times.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What I posted a photo, no comments?
    Apr 2010
    East Texas
    9,640
    Looks just fine now!....(minus skid marks)
    Feb 2014
    Central Minnesota
    5,080
    Skid marks are a nice touch. Character!
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    I bet that was fun to explain to the insurance company?
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Jun 2012
    SW Pennsylvania
    77
    Beautiful room...with character and a story!
    AG AquaLeader 21x43 Oval 54" deep. Hayward 2speed 2HP pump,Hayward 350,000 BTU NG Heater, Cartridge filter. Since August 2012. TFT 100 test kit
