Results 1 to 7 of 7
Thread: Need help on new Taylor test kit-chlorine test stays pink...
    Hi all,
    First time using new Taylor testing kit and I feel like I'm doing something wrong with the chlorine test. I added the 2 tiny scoops for the powder stuff and the water turns pink. I then add the drops, one at a time to determine FC. After about 20 drops, I stopped(water was still pink), as I felt like I was using too much. I added chlorine a week ago, and it was very sunny this weekend. In process of raising cya, but estimate that it's around 20. I just find it hard to believe that FC is still so high. Is there something else that would cause the reading to be off?
    Thanks!
    27K gallon, IG vinyl pool, SD80 Sand Dollar sand filter-Michigan, 1hp pump
    Aug 2011
    Southern California
    188
    Re: Need help on new Taylor test kit-chlorine test stays pink...
    Are you using the 25 ml or 10ml test? 20 drops on the 25ml test would only be 4.0 so not abnormal at all. Heck even a 10ml test it would be 10
    Continue adding drops until it turns clear. Then multiply by whatever test variant you are using
    May 2011
    Orange, TX
    66
    Assuming you are using the Taylor K2006. Swirl the water after adding the powder. Ensure you are using the brown bottle (R-0871) for your drops after the powder. Make sure you swirl the sample after each drop. Using a 10mL water sample with the 20 drops will provide you with 10ppm of FC, which isn't all that high. (High if you haven't added chlorine in a week). If you used a 25mL sample then 20 drops is a FC of 5. You can always double check yourself with the OTO test if you have a kit. There are cheap at almost any department store.
    20,500 gallon free form, 6X9 hot tub w/ spillover, 18" jumping platform w/ 3ft shear descent on chopped rock, Travertine coping, 2.5HP Hayward 2-speed filter pump, 525 Hayward Cartridge filter, 350K BTU Hayward NG Heater, 2HP Hayward water feature pump, Satin Matrix Northshore Carribbean, Jandy PDS-8 Controls
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    You're using the R-871 reagent not the R-0003, right?
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Aug 2011
    Southern California
    188
    Quote Originally Posted by Starplex View Post
    That should be 4, not 5.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Same exact test reagents as your K-2006.
    Thanks for all the replies. I did a few tests over the past week, using both the large and smaller amounts, trying to figure out which was better. I think I had it in my head that the last test using the 25ml sample would require fewer drops. My pool water is still very cold, so that must also be helping to maintain the chlorine levels.
    Thanks again!
