Results 1 to 7 of 7
Thread: HELP -- NO Free Chlorine reading and phosphates -- pool store not helping
    Jun 2014
    Pittsburgh, PA
    2
    Hi There,
    I could not be more frustrated. I have read a few of the email chains and I am having the same issue that I had 2 years ago -- my pool water is very cloudy, I can see some algae in the corners, and I cannot get a FC reading. We went to the pool store and they said we have phosphates (reading of 1200) and that we need to buy a phosphate remover. well after $600 dollars of phosphate remover 2 years ago, nothing helped, so I slammed the pool based on the recommendation form this site and finally got the pool in working condition. I am trying to do the same now, but having trouble getting a FC reading -- can you help me determine how much bleach I should put in initially and then how I should look athe reading to determine the rest. Here are the latest readings:
    TC: 10
    FC: 0
    PH 6.9
    Total Alkalinity: 140
    Calcium Hardness: 300
    Stabilizer: 40
    Thanks you for any help that you can give.
    I should mention that the pool is 18X36, about 25,000 gallons has a liner and we have a Hayward Sand filter.
    Also, we have had this pool for 14 years and NEVER an issue until 2 years ago. UGH!!!
    Signed, SO Frustarted!
    30,431
    Re: HELP -- NO Free Chlorine reading and phosphates -- pool store not helping
    Welcome to the forum.
    Your TC cannot be 10 with an FC of 0....review your post for typos or review your test methods.
    With a CYA of 40 ppm, your SLAM value for chlorine is 16 ppm. That means you have to hold 16 ppm FC until your pool clears.
    The SLAM process is as simple as following the SLAM article to a "T" up in Pool School. When that process is complete, your pool will be crystal clear.
    Jun 2014
    Pittsburgh, PA
    2
    Thank your for the reply, and thanks for the welcome. That reading is from the pool store What would this reading mean then???
    We just bought our own test kit, so I will do my own test when I get home. I will send the pics too. Thanks for your help., I will keep you updated.
    30,431
    i really have no idea....I would be simply guessing.
    Post your own test results when you get that kit. We trust your testing FAR more than the pool store's.
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    ...oops
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    tucsontico's Avatar
    Mar 2014
    202
    Quote Originally Posted by Vblatt View Post
    Hi There,
    TC: 10
    FC: 0
    PH 6.9
    Stabilizer: 40
    First things first, did the numbers listed above come from a pool store? If so, you NEED to get a good quality test kit–either a Taylor K-2006 or a TF-100–ASAP. There is NO OTHER WAY to properly and consistently measure what's going on in your pool. The pool store–as you found out–can never know your pool as well as you do/will. If these numbers came from your own testing, be certain your testing chemicals have been stored properly, i.e., have NOT been exposed to extremes of temperature, etc.. The next thing to do is to read, reread, and read again these Pool School articles:
    1. http://www.troublefreepool.com/conte...ater-chemistry
    2. http://www.troublefreepool.com/conte...lving-problems
    3. http://www.troublefreepool.com/conte...ool-calculator
    The last article has an embedded link to the Pool Math calculator. You can enter your pool size, finish and chemistry test data into the calculator and it will give you amounts of chemicals to add based on what you need to do to clear/balance your pool.
    I am not an expert but you can ignore the phosphate numbers. Removing the phosphates won't kill the algae–only chlorine will. So don't waste any more money at the pool store. I would recommend getting a lot of bleach (10-15 gallons) to ready for the SLAM process. There are many experts on this forum and, if you follow their advice, you'll have a clean, trouble-free pool.
    Lastly, you will need some POP (Pool Owner Patience) for any chemical process to work. You didn't get algae overnight and you won't be rid of it overnight either.
    Good luck!
    Listen to duraleigh!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok, thing one get your pH up to the normal range, then worry about the rest, if you don't have a good quality test kit, get one, see my signature for the TF-100 link. In general our experience has shown that pool store testing is often about as reliable as a ouji board, so having your own quality test kit is the only practical solution to these sorts of problems.
    Ike
