Results 1 to 7 of 7
Thread: Test numbers - how do they look?
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Been trying to get the water balanced. Here are my current results:
    FC 7
    CC 0
    pH 7.4
    TA 50
    CH 130
    CYA 50
    I was thinking of using Cal-Hypo until CH comes up to the 220 range, but that might take a long time. Looks like I need to add about 5 lbs of baking soda to raise TA to 70. Any suggestions?
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    30,431
    Re: Test numbers - how do they look?
    How do you chlorinate? SWG or manual? How does your water look?
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    I manually chlorinate. I've been using bleach to SLAM for a few days and the water is gorgeous.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    I'd say you have things figured out.
    Yes to raising TA with baking soda.
    I don't know that I'd worry about CH in a fiberglass pool. But some simple number crunching says that if you lose 2 FC each day and use Cal-hypo to chlorinate, you'll add 10 CH every week. A 25 lb bucket will add 87 CH. Your call.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    If CH is not critical with fiberglass, I'll just raise TA and enjoy the pool. Bleach will be much cheaper than a big bucket of 73% cal hypo from the pool store.
    30,431
    That's a great ;looking pool and great looking pool water!
    I can't add anything to Richard320's excellent post.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Thanks! I'll pick up some Bakin' soda and go to work.
