Results 1 to 11 of 11
Thread: Opened to a pond, still cloudy and other problems...
    Mar 2010
    Huntington, WV
    150
    My winter cover had a hole in it and we opened the pool 2 weeks ago to a pond with lots of frogs and green water. After all of the organic material was vacuumed and scooped out, I brought the pool water level up to where it is supposed to be and added the chemicals needed. I shocked it 3 times hoping that it would kill anything else that tried to start blooming. We still have cloudiness, but it is not improving. I shocked it again last night but was hoping this morning after running the pump all night it would be fairly clear, but it was not. Here are my current numbers:
    TA: 50
    PH: 7.2
    Chlorine: 6.0 (post shock)
    CYA: 70
    Salt: 2150
    Also, I have noticed that there are some floating things in the pool that kind of resembles soap, but its not really foamy. I read that it could be from air on the suction side. I have replaced the o-ring on the pump lid but it still appears that there is some bubbles in that basket. I am not sure what else to check.
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Opened to a pond, still cloudy and other problems...
    Does the pool foam look like this:
    Just do what he did. http://www.troublefreepool.com/threa...ark-Green-Pool
    Or is it more like this:
    Either way, the solution is a SLAM. It's like a shock but it is sustained for days. If you don't have the prerequisites, don't try it.
    Mar 2010
    Huntington, WV
    150
    Its definitely the first picture. But my water is not green, its just cloudy with the bubbles.
    And what is the SLAM process?
    24' AGP
    Richard320's Avatar
    Jan 2010
    19,037
    Mar 2010
    Huntington, WV
    150
    This is how it looks today. It was a dark green, now its less green but cloudy with these bubbles.
    24' AGP
    Mar 2010
    Huntington, WV
    150
    What about the bubbles in the pump basket?
    24' AGP
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by Jeff74 View Post
    A bubble stuck in the top of the lid is pretty normal. Do you see bubbles coming out of the returns in the pool?
    If it isn't the lid O-ring, check the drain plugs on the pump, that the water in the skimmer isn't too low and creating a vortex, that the skimmer flapper isn't sticking.
    Mar 2010
    Huntington, WV
    150
    There are some bubbles coming out of the return jet but not anymore than there was last year. The pump basket isn't churning but there are lots of little bubbles but "a" bubble in the top as you mentioned. I replaced the o ring. Where are the drain plugs? There is one right near the basket on the pump but I thought this was a air pressure release?
    24' AGP
    Richard320's Avatar
    Jan 2010
    19,037
    There's usually one or two drain plugs on the pump body. Look for your manual online and study the parts diagram, that will show you how many and where.
    Tiny bubbles in the returns could be from the SWG. See if they go away when you shut the SWG off for a few minutes with the pump on.
    Mar 2010
    Huntington, WV
    150
    Once I find the drain plugs, what do I need to look for with them?
    24' AGP
    Richard320's Avatar
    Jan 2010
    19,037
    They might have an O-ring, or they're tapered pipe plugs. The parts blowup will show an O-ring. Make sure it's there and the plug is snug with your finger. If it's a pipe thread (it may say something like "plug, 1/4" NPT") make sure it has some teflon tape on it and it's screwed in tight with a wrench.
