Thread: Opened to a pond, still cloudy and other problems...
    Mar 2010
    Huntington, WV
    150
    My winter cover had a hole in it and we opened the pool 2 weeks ago to a pond with lots of frogs and green water. After all of the organic material was vacuumed and scooped out, I brought the pool water level up to where it is supposed to be and added the chemicals needed. I shocked it 3 times hoping that it would kill anything else that tried to start blooming. We still have cloudiness, but it is not improving. I shocked it again last night but was hoping this morning after running the pump all night it would be fairly clear, but it was not. Here are my current numbers:
    TA: 50
    PH: 7.2
    Chlorine: 6.0 (post shock)
    CYA: 70
    Salt: 2150
    Also, I have noticed that there are some floating things in the pool that kind of resembles soap, but its not really foamy. I read that it could be from air on the suction side. I have replaced the o-ring on the pump lid but it still appears that there is some bubbles in that basket. I am not sure what else to check.
    24' AGP
    Hayward Power-Flo LX 1.5hp pump
    Hayward Pro Series S180T 150lb sand filter
    Intex 54601EG Krystal Clear SWG
    Diver Dave pool cleaner
    30,411
    Re: Opened to a pond, still cloudy and other problems...
    You need to SLAM the pool to get it clear. read "SLAM" in the "How To" section up in Pool School. Your FC should be @ 28 ppm and HELD THERE until you complete the SLAM.
    Completing the SLAM involves 3 parameters to meet.
    1. Your pool water is sparkling
    2. Your CC's are .5ppm or less
    3. You can hold your FC overnight without losing more than 1ppm.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Your CYA is quite high, so your FC will need to be too.... Duraleigh is very correct...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2010
    Huntington, WV
    150
    CYA is normal for SWG according to pool school.
    24' AGP
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yes for SWG its totally normal, I have a vinyl pool, but when SLAMming your pool, your FC needs to match the CYA....
    http://www.troublefreepool.com/conte...art-slam-shock
    Casey's Avatar
    SW PA
    10,427
    Shock Level And Maintain. SLAM it Jeff! Don't let up until you can see the head of a penny on the floor.
