Results 1 to 10 of 10
Thread: Intex 18x9x52 level question
    Jun 2014
    Douglasville/GA
    5
    Cool Intex 18x9x52 level question
    Hello,
    First time pool for our family, and we bought the intex 18x9x52.
    So, here is the question...
    After leveling (so I thought) in the hot GA sun and hard red clay... we filled the pool only to find it out of level by 2.5" at the most out of level spot. It seems we have a high corner which has shifted water to the opposite diagonal corner. We used sod cutter and removed the sod, used long 2x4s and 6' level... tamped the whole area then added about 1/4 of sand and tamped/smoothed out.... level showed level and looked real level, so thought we were good. Put down the tarp then gorilla pad, last the pool and set up and filled.
    Water Depth:
    Low corner is 44
    Opposite same short side 42 3/8
    Opposite same long side 42
    Opposite diagonal 41
    Do y'all think this will be okay to swim in?
    Seems all the corners and rails are moving smoothly as they should, and none of the support legs looked stressed.
    Your input is greatly appreciated....
    Thank you
    [IMG][/IMG]
    [IMG][/IMG]
    38,475
    Re: Intex 18x9x52 level question
    Welcome to TFP!!!
    First, a raised corner does not "shift" the water. The water is ALWAYS level.
    Industry standard is having the pool level within 1" ... outside of that you are taking a risk and we are not in a position to say whether you will be fine or not. That is a judgement call up to you.
    Jun 2014
    Douglasville/GA
    5
    Is there anyone out there that has been in similar situation and their pool held up just fine?
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Mine looked like that for the last part of my summer last year..... I took it down at the end of summer, but you should be able to get one season out of it... Its not as bad as some of the tolerances, and because the legs on our pool are different to the round legs, we've got a bit more stability... So yeah, it should be ok for this summer...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2014
    Douglasville/GA
    5
    Thanks Laceygirl! I got in the pool today and did some aggressive laps and jumped and made some good waves... did fine. Some water sloshed out of that corner where the water level is high, but it wasn't much. I thinking about keeping it up this summer, then in the fall take it down and store for the winter. In the spring re-level as you are doing.
    Would love to hear others still... even those that had a collapse.
    Thanks again
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    You are welcome new pool... You won't find many intex threads with liners that fail, but you will find threads that show the frame failing first... Usually from rust, and that can be from 2 - 5 years depending on where you live... The liners are pretty tough.... I believe they're almost 3mm thick.... Sorry I use metric... Have you thought about installing a through the wall skimmer for it?
    Jun 2014
    Douglasville/GA
    5
    I have the intex deluxe wall skimmer. Its not a through the wall... it attaches to the frame and hangs in the pool. Seems to be working fine. I do have the sand filter and saltwater system.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    The through the wall skimmer is pretty awesome, but it means you will have to cut the liner... I'm doing it this year... Here's a thread showing how its done... Something to think about for the future... You'll find the arms break off those over the wall skimmers......
    http://www.troublefreepool.com/threa...nd-ready-to-go!!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Here's where you can get one super cheap... For future reference... http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    I have an 18 foot round that has over the last 3 years settled to being about 3" out of level. It is holding up fine, and it has had many rowdy teenagers and young adults flailing about at the same time. That being said, it is a round pool and the stresses are probably more even then in a rectangular pool.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
