Results 1 to 8 of 8
Thread: London Broil, the true classic recipe
    May 2014
    Montpelier, Virginia
    54
    London Broil is a great outdoor summer steak and it is as easy as it comes.
    Flank Steak 3 lb average, when its on sale I buy it up.
    all you do is marinate it in Regular Kraft Catalina French Dressing for 24 hours. Not low fat.
    You grill the whole Flank to your desired temperature, cut into the middle of the flank if you do not have a great feel for steak temps and check.
    Once cooked throw it on your large cutting board with longer ends horizontally across your cutting board
    Best using a carving knife lay you knife almost flat against the flank and carve thin slices. Once I am done scrubbing my pool till my arms fall off I will post a video.
    Sautee up some mushrooms to go on top. YUM
    40,000 gallon, vinyl liner, sand filter, oldie but goodie, Chef for all your cooking questions!
    Jun 2014
    Central Florida
    36
    Re: London Broil, the true classic recipe
    Catalina is also what I use to marinate flanks and londons. Another one of my favs is to marinate shrimp and scallop kabobs In teriyaki sauce and toss them in a grill basket with some peppers and onions.
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Casey's Avatar
    SW PA
    10,428
    Never marinated with Catalina. I'll have to try that!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Tedb
    Dittos to that. I've done the same thing and it turns out great!
    Butterfly's Avatar
    South Carolina
    10,045
    nummy nummy
    You're done SLAMing when:
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    Quote Originally Posted by Casey View Post
    Count me in the "never used before" crowd.
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Oct 2007
    Valrico, FL
    542
    We have used Good Seasonings Italian salad dressing mix for a marinade. Now we are mostly going with rubs. However I agree London Broil is excellent on the grill.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    May 2012
    Montville NJ
    545
    London Broil seems to be the only thing that goes on sale anymore around here.
    I like to marinade it overnight in a mix of soy, worcestershire, mustard, molasses, vegetable oil, and liquid smoke overnight.
    I prefer flank steak, but it is over $2 a pound more.
    I REALLY like hanger steak (onglet) but that is also pricey (and I don't marinate that, just grill, slice, and serve over pommes frite). A sprinkle of salt and pepper and you are good to go.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
