Thread: My readings after about 2.5 inches of rainfall
    Apr 2014
    Florida
    14
    I have my test kit Taylor 2006 and I put all my numbers in the poolmath.....
    FC=6.5
    CC=0.5
    PH=7.5
    TA=125
    CYA=40 (outside but cloudy no sun ...till I no longer see black dot)
    CH 425
    Water Temp 80
    My TA is high and CH....poolmath says just to add to CYA but nothing for TA is this right? Thank you for all your help and I am really happy to find this forum...so much useful info!!
    PebbleTec, inground pool, 15,200,IC60 Pentair IECG, Heliocol solar panels, Pentair Intelliflo variable speed pump
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: My readings after about 2.5 inches of rainfall
    You can add muriatic acid to lower your PH to 7.2........aerate the pool to raise PH again............then add more acid which will lower your TA. It is a process..takes awhile. Your cya might need to be 50 depending on chlorine consumption.
    Apr 2014
    Florida
    14
    Ok, I will add the muriatic acid. I am just nervous about adding CYA ...because it was up there at one point....does it make a difference if sun is not out when doing this test? I know it says to do it with back to sun...maybe I will wait and see if the sun comes out again then retest CYA.
    30,432
    Leave it alone if it makes you uncomfortable. I would raise it to 50 in FLorida, as woodyp suggests, but you can always go up there after a couple of weeks when your pool is "tuned in" better
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I'd just leave it alone and go swimming.
    If you keep CYA at the low end, you have room to use pucks in a floater if you leave town on vacation.
    Apr 2014
    Florida
    14
    Thanks for your help ...I will leave alone.
