Results 1 to 10 of 10
Thread: SPA/Hot tub chemistry question....
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    My spa/hot tub is connected to my pool so this question is for the folks who have a stand alone system:
    Is the chemistry the same? What I mean is, do you still add the same types of stuff as you would your pool? Bleach, muriatic acid, borax....and the such? Just curious. I was in Leslies the other day buying a new o-ring and there was a couple in there asking questions and naturally they were sold about $75 worth of product so I gave them this website info and told them to read and ask questions before dumping that stuff in there. I'm just looking to be informed for the next time I run into someone in this situation. Thank you all!
    ~Carl
    IG Plaster with raised spill-over Spa, ~26,000 gallons, Built 2001
    Cartridge filter
    Solar heated
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: SPA/Hot tub chemistry question....
    I chlorinate my pool and spa with the exact same chemicals. Test with the same kit. Etc, etc, etc. I do tend to push my FC higher in the hot tub because I don't lose it to sunlight (mostly covered) so I can wait longer between testing/adding bleach.
    Wait! There is one difference! I use 8.25% bleach in the hot tub, 12.5% in the pool. Lower hypochlorite concentration is more stable and easier to bump up FC with larger volumes in a small tub.
    Isolated Spa - 345 Gallons
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Thanks Joel...so on the Pool Math calculator, you just substitute your numbers in? Number of gallons of water....blah blah blah....and are the targets still the same based on the FC/CYA charts? Sorry for the dumb question but I just don't want people to be discouraged from the enjoyment that we all partake in! LOL!
    Cartridge filter
    Solar heated
    For a stand alone spa you use different TA levels, and you add chlorine after each time you use the spa as well as on a regular schedule. But by and large things are very similar. See the sticky at the top of the Spa/Hot Tub section of the forum.
    Feb 2014
    Central Minnesota
    5,080
    Yep. All the same. For full details on maybe some slight variations on start up and maintenance this thread is AWESOME. How do I use Chlorine in my Spa
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Thanks Jason.
    Cartridge filter
    Solar heated
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Also non-chlorine sanitation options are a lot more popular in Hot Tubs than pools, I am including use of Bromine in this as well as mineral / MPS etc.
    May 2012
    Toronto, ON
    463
    What about SWG for spas - is that an option?
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It is, in fact I have one
    Mar 2007
    San Rafael, CA USA
    12,082
